Aqualung Posted September 28, 2017 Posted September 28, 2017 Hi,I'm new to the forum.My name is Rich and I'm the proud owner of a lovely old 1993 Honda cb 750 f2 n .Just one of the loveliest bikes I've had .The story so far.Had bike about six years .Started sticking in gear the other day,so dropped her into where I have it moted to see what they thought .Got years ticket mot as was due anyway at the time .They said needed new clutch ,so said go ahead .Got phone call about week later,not clutch ,transmission ,will cost about £1000 to split her etc .Thought ,oh dear,or worse to that effect ,can't afford that.So,decided to get them to bring her back in there van,another £50 although they said don't need to pay for the new clutch they put in as there mistake .Bit odd?Didn't ride it back as they said will stick in forth then you will have to wait for it to cool down and put it in gear by hand and start off again ?Anyway ,in meantime started looking for a cheap runabout to get to work .Found a Yami 600 for £700 miles away ,had to change over insurance ,tax etc.Well,put battery on Honda today so could put it behind Shed ,but seemed to go into gear ok .Took up lane and seemed better than before going into all gears.Worried now as just got another bike I didn't want .Cant ride it far as no insurance or tax on it as cancelled thinking bike no good,broken gearbox like they told me .How can it work ok up and down lane but so called get stuck in gear after a long run .Surely if it was a gearbox problem it would do the same i at any time ?Have I made a huge mistake buying another bike for no reason?Trouble is for me to find out I will have to tax and insure the Honda again ,that means two bikes with tax and insurance which I cannot afford.Please,please can you give any advice.So,sorry it's a long one .Rich Quote
fastbob Posted September 29, 2017 Posted September 29, 2017 I had a GS550 that only got stuck in gear when it got hot so I think its wishful thinking to believe the fault has gone away I'm afraid. Now that you have a second bike you have all winter to fix the gearbox yourself. Its probably a bent or worn selector fork. The best thing to do now is read and re read the Haynes manual until you have a good grasp of what's involved. I've done this job myself and it's not as daunting as it might seem. Quote
BIKERDAD Posted June 19, 2018 Posted June 19, 2018 Hi how did the CB750 go after ..did you fix It or leave it .. Quote
Guest Posted July 14, 2018 Posted July 14, 2018 I had a GS550 that only got stuck in gear when it got hot so I think its wishful thinking to believe the fault has gone away I'm afraid. Now that you have a second bike you have all winter to fix the gearbox yourself. Its probably a bent or worn selector fork. The best thing to do now is read and re read the Haynes manual until you have a good grasp of what's involved. I've done this job myself and it's not as daunting as it might seem. Agree......not a complicated job to mend it yourself, if you've got the manual for it.I reckon fastbob's right - it will probably be something to do with the selector mechanism. Only thing to watch is if you can't get new parts, be very wary about buying 2nd hand stuff sight unseen. I has an XS750 2D that ate it's selector drum and almost every drum that I found in various breakers had the same pattern of wear. Eventually found a replacement in Southwark, of all places, fitted it and all,was well again. I think that's why the 750 2D was eventually replaced by the XS850, but there were never as many of them about as the 750s. Quote
TimR Posted July 14, 2018 Posted July 14, 2018 I had a GS550 that only got stuck in gear when it got hot so I think its wishful thinking to believe the fault has gone away I'm afraid. Now that you have a second bike you have all winter to fix the gearbox yourself. Its probably a bent or worn selector fork. The best thing to do now is read and re read the Haynes manual until you have a good grasp of what's involved. I've done this job myself and it's not as daunting as it might seem. Agree......not a complicated job to mend it yourself, if you've got the manual for it.I reckon fastbob's right - it will probably be something to do with the selector mechanism. Only thing to watch is if you can't get new parts, be very wary about buying 2nd hand stuff sight unseen. I has an XS750 2D that ate it's selector drum and almost every drum that I found in various breakers had the same pattern of wear. Eventually found a replacement in Southwark, of all places, fitted it and all,was well again. I think that's why the 750 2D was eventually replaced by the XS850, but there were never as many of them about as the 750s. 9mnths on he may have fixed it .... Quote
Guest Posted July 15, 2018 Posted July 15, 2018 I had a GS550 that only got stuck in gear when it got hot so I think its wishful thinking to believe the fault has gone away I'm afraid. Now that you have a second bike you have all winter to fix the gearbox yourself. Its probably a bent or worn selector fork. The best thing to do now is read and re read the Haynes manual until you have a good grasp of what's involved. I've done this job myself and it's not as daunting as it might seem. Agree......not a complicated job to mend it yourself, if you've got the manual for it.I reckon fastbob's right - it will probably be something to do with the selector mechanism. Only thing to watch is if you can't get new parts, be very wary about buying 2nd hand stuff sight unseen. I has an XS750 2D that ate it's selector drum and almost every drum that I found in various breakers had the same pattern of wear. Eventually found a replacement in Southwark, of all places, fitted it and all,was well again. I think that's why the 750 2D was eventually replaced by the XS850, but there were never as many of them about as the 750s. 9mnths on he may have fixed it .......or it could be under a tarp in the back yard....... Quote
