Race cans...non E approved?
I have a rsv with Renegade race pipes, i have been advised to remove the "for competition use only " and am unsure whether to attach a type approval badge or rivet band.... any help greatly appreciated! steve :wink:
I had an exhaust that had that taken off once and it looked a mess which kind of makes it obvious what had been done. Whatever you do, you want it to look like it came from the manufacturers like that, a rivet band sounds a good idea but it might look odd because you only really get one at each end. Maybe a better solution would be to remove the original rivet band from the end, cut down the sleeve and then re-rivet the end back on.
removing the "for competition use only" and fitting the bands is classed as trying to evade the law and fraud and carries a big fine :shock:
just leave them as they are and suffer the £30 fine and 7 day rectification notice if caught :)
