Ryoni32 Posted April 27, 2018 Author Share Posted April 27, 2018 OK now I notice cleaned carb put fuel hose on carb turn tap to reserve trickles into pipe. Take hose of carb n turn tap on pours out no probs any ideas Quote Link to comment Share on other sites More sharing options...
Ryoni32 Posted April 27, 2018 Author Share Posted April 27, 2018 I do have a short video but not sure how to show you guys unless I put it on YouTube Quote Link to comment Share on other sites More sharing options...
JRH Posted April 27, 2018 Share Posted April 27, 2018 I do have a short video but not sure how to show you guys unless I put it on YouTube Yep, use YouTube and then add link. Quote Link to comment Share on other sites More sharing options...
Ryoni32 Posted April 27, 2018 Author Share Posted April 27, 2018 https://youtu.be/ow0NQd1ldmQ Quote Link to comment Share on other sites More sharing options...
Via Posted April 27, 2018 Share Posted April 27, 2018 If you get fuel flowing with pipe pulled off and then reconnect to carb (without turning tap off - will be bit messy) does flow stop?Also weird you have to fiddle with tap when pulled off, if there was a problem with it flowing into carb should still have flowed as soon as you pulled off the carb, maybe bit of a temperamental tap? Quote Link to comment Share on other sites More sharing options...
Ryoni32 Posted April 27, 2018 Author Share Posted April 27, 2018 It's annoying kus this bike will run and does run just so boggy. Only thing can't get to is diaphragm as screws are rusted up to fook and chewed up Quote Link to comment Share on other sites More sharing options...
JRH Posted April 27, 2018 Share Posted April 27, 2018 Re- connect the fuel pipe, turn the fuel tap on then open the carb drain screw and then check the fuel flow through the system. If no fuel flows out through the drain then either the tap is faulty or the carb inlet is blocked. Quote Link to comment Share on other sites More sharing options...
Rickymatthews Posted October 26, 2022 Share Posted October 26, 2022 Hello there just wondering are u selling the fuel tank are have u got one for sale thank u Quote Link to comment Share on other sites More sharing options...
Tiggie Posted October 26, 2022 Share Posted October 26, 2022 The person who started this topic hasn't been back since April 2018 so you might want to try elsewhere for a tank Quote Link to comment Share on other sites More sharing options...
