megawatt Posted July 31, 2018 Share Posted July 31, 2018 Do it yerself. Quote Link to comment Share on other sites More sharing options...
Tango Posted July 31, 2018 Share Posted July 31, 2018 No need to drain the oil......just remove the cam cover and fit a new gasket and away you go...... Quote Link to comment Share on other sites More sharing options...
Guest Posted July 31, 2018 Share Posted July 31, 2018 It will be easier if you remove the tank first but otherwise a comparatively simple job.... Just don't go mad when you tighten the screws up when you put the cam cover back on. A bit of grease will hold the new gasket in place when you replace it. Quote Link to comment Share on other sites More sharing options...
BIKERDAD Posted August 1, 2018 Author Share Posted August 1, 2018 Ok I'll have a go see how much the gaskets are . . AND get back to once iv done it .. thanks Quote Link to comment Share on other sites More sharing options...
