I have 10 Dowty washers ( rubber with metal inserts ) that fit under the cam cover bolts on the Trophy.
They were caked in a hard residue that I reckon was limescale, replacements are about £5 each.
After a bit of research I created a mixture of white wine vinegar and lemon juice & left the washers to stew over night.
This morning most of the lime scale had disappeared and what was left could be easily scraped out of the grooves with a cocktail stick.
Rinsed and dried - job done 👍
Saved myself £50
You must use gold plated Dowty washers :shock:
They are Triumph OE parts - nuff said
Should have used Cillit Bang ( I am not Barry Scott )
I doubt whether Triumph actually make these.... If they can source them, so can you....
