CoreyMatthew_ Posted March 3, 2019 Posted March 3, 2019 https://imgur.com/a/hMhcvsh' alt='IMGUR>'>Hi, I have a lexmoto tornado 50cc which I recently purchased... I have noticed the bike does around 20mph without throttling and have noticed this is very dangerous for when trying to stop, reverse which is almost impossible.does anyone have a solution to this problem? I thought it could've been an automatic chock but when I've taken it out to have a look they are nothing I can loosen or even tighten to decrease/increase the amount of air into the bike. Quote
TimR Posted March 3, 2019 Posted March 3, 2019 put bike on centre stand so rear wheel is off ground start bike and let it idle ( dont touch throttle)is it idling high so it spins the back wheel does it have a rev counter a typical bike engine will idle at 800-1200 rpm if its higher locate the idle screw/adjuster ( do some research or look in owners manual ) but make sure it is the idle screw .and turn this anticlockwise until revs drop ( but count the amount of turns you make)if this has no effect look next to throttle grip where cables exit there are two adjustetment points slacken these ( make them smaller ) and see if that has any effect .ie bike stops or revs dropif it does make those adjusters as small as possible turn the idle screw clockwise half the amount of turns you undid it by and try starting bike ..try to get the idle to the point where the bike keeps running smoothly without racing between those figures above .Then google throttle cable adjustment so that you understand what it is your actually doing and need to do adjust the cable adjusters correctly so that engine speed is not altered by them . Quote
fastbob Posted March 3, 2019 Posted March 3, 2019 As above, there has to be an idle speed adjuster somewhere on the carb . Quote
Guest Posted March 3, 2019 Posted March 3, 2019 Does the engine speed vary with the position of the handlebars? If so, badly routed or wrong throttle cable. Quote
fastbob Posted March 4, 2019 Posted March 4, 2019 It's a carburetor Jim , but not as we know it . It looks like a CV carb so that screw sticking up with the spring on it looks like the one to go for because it would control the opening of the butterfly valve.Turning it out ( clockwise ) should bring the idle speed down . Quote
TimR Posted March 4, 2019 Posted March 4, 2019 It's a carburetor Jim , but not as we know it . It looks like a CV carb so that screw sticking up with the spring on it looks like the one to go for because it would control the opening of the butterfly valve.Turning it out ( clockwise ) should bring the idle speed down . surely you mean anti clockwise for out ? Quote
fastbob Posted March 5, 2019 Posted March 5, 2019 It's a carburetor Jim , but not as we know it . It looks like a CV carb so that screw sticking up with the spring on it looks like the one to go for because it would control the opening of the butterfly valve.Turning it out ( clockwise ) should bring the idle speed down . surely you mean anti clockwise for out ? Sorry,I certainly do. Quote
