Bender Posted May 16, 2024 Posted May 16, 2024 1 hour ago, Mississippi Bullfrog said: So far everyone has got this wrong. It is very very simple. At all times your tyres should be facing down. If they are facing the sky you have crashed. The top of the tyre often faces the sky, unless cornering where it will point at the hedgerow 1 1 Quote
RideWithStyles Posted May 16, 2024 Posted May 16, 2024 (edited) . the tyre faces 360 degree, mostly on a flatish axis, they should be rolling towards the direction intended with the profile curvature of the tyre (motorbike unquie design) allowing . Edited May 16, 2024 by RideWithStyles 1 1 Quote
Mickly Posted May 16, 2024 Posted May 16, 2024 They should be facing the way you are going, if they don’t then you will get lost 1 1 Quote
