Welcome to the forum
Do you get any clutch drag when holding the clutch in with it in gear?
Sounds like it could be warped clutch plates
hi no clutch drag, do 50 miles and its hard to select 1st and cant get it into neutral. wait till it cools down and its ok ?
Worn selector forks would be my guess . Not a difficult job because it has a horizontally split crank case . You might be able to ignore the Haynes manual and take a few shortcuts such as leaving the Clutch basket and rotor in place . Here's an interesting video that I came upon that will give you some idea what's involved . Pity it's speeded up . https://www.howtomotorcyclerepair.com/cb550bottomendrebuild/
