Knocking noise in 1st gear
Hi all, need help please......
I own a quadzilla 250 and i have just started to get a knocking noise only in 1st gear.
Just wondering if anyone knows what this could be??? And if it would be expensive to fix
Dont know nothing about bikes so if you need more info on the problem let me know
Thanks in advance :wink:
Don't take this as gospel, but it sounds to me like a few teeth have come off first gear, in which case it could lock up at any moment. :cry:
If it is your gearbox, then yes, and it'll be serious money :cry:
unless you do it yourself :)
where is the noise comming from ?
wow just scare the crap right out him why dont you :lol:
could be as simple as tightening the chain to the gearbox is fooooked :wink:
more info needed m8, which side and what kind of noise :wink:
wow just scare the cr@p right out him why dont you :lol:
I know, but he says its only in first gear so I doubt its anything to do with the chain
might not hear it at higher speed :wink:
It is only in 1st gear, i have listened for it in all the other gears.
Its coming from around the front sprocket area.
The only way i can explain it is that its a knocking sound, the faster i go in 1st the faster the knocking :cry:
I have no idea mate. I will have another listen tomorrow to try and find out.
BTW anyone want to buy a quad lol
How much am i looking at if it is 1st gear gone?
hundreds??
hundreds??
It cost me about £500 to have a gearbox repaired.
If it is your gearbox and one of the cogs has lost some teeth, the teeth will be floating about and could cause it to seize up, so be careful if your riding it. Personally I wouldn't use it.
if you can do it yourself it will be about £200 ish probably a lot less depends on the price of parts
what motor is in it ?
personaly I would tighten the chain and check sprockets :wink:
put money on the teeth broke on first cog--would go bearings if in all gears
thanks guys, i have just put it on ebay. I have spent loads on it already and am not going to spend anymore on it.
Anyway the mrs seems to think the our 14 weeks old daughter and the mortgage should come before my toys :lol:
not too big a job if the gear box has gone, i did my r6 in 13 hours, start to finish, engine out, replace gear box and back together in the bike and a clean.
if its just 1st gear gone, say 100 quid in parts if you can do it yourself.
How much on ebay have you put the quad up for and can i have the link for it??
I could get it sorted for 100-200 quid lol
Matty
