Hello and thanks for taking the time to read my post. I am the owner of a 93 Kawasaki ZX7 and my newly recovered stolen Kawasaki 650r 2007.
I know I'm probably out of line with this context or not doing everything correct order this form ask. But I am in desperate help for have search for 3 days and no avail. Okay my 2007 Ninja 650r the guys who stole it did a number on the wiring I have since then got the bike running but after a while it will cut out on me because the battery dies due to fuel pump and lights using all the batterys power.
I have searched and searched wiring diagrams for the R/R. But all I seem to find is post with the RR having yellow wires connected to it three of them to be exact and it varies from three to two to five colored wires.
My r/r has three black wires one black with a yellow stripe one white with a blue stripe and one tan. Could somebody please tell me which one of these three colored wires do I hook to the positive post to the battery so my battery would charge thank you for your time your patience and sorry if I'm out of line with this form but I'm ready to get on the road with this bike being how my ZX7 is in the shop needing copy and rebuild thanks a lot.
Posted (edited)
17 minutes ago, NeilM said:
Post some pics
Or haven’t you it nicked it yet .....🤣
Edited by Trooper74
Posted (edited)
Okay this hooks to my regulator rectifier...
If I'm correct one of these wires should be hooked to the positive of my battery so I will get a charge when my bike is running I mean right or wrong .   like for instance my other two bikes they have generators are alternators on them to run the lights and things this bike does not it has this regulator rectifier one of these wires should somehow be connected back to the positive of my battery which one
Edited by Datboy478
There you have three small blacks at the bottom a thick black with a yellow stripe a thick white with a blue stripe and a thin tan wire.
