Troy Posted April 23, 2022 Share Posted April 23, 2022 Had to get two new tyres done today after a puncture that was soo big it couldn’t be plugged and the front was on its limit any way. The only tyres they had in stock was the Pilot Powers. Has anyone used them before? Can you give me your ratings? I'm coming from Pirelli Rosso 3s. Ride at weekends with some “spirit” but no heroics. Quote Link to comment Share on other sites More sharing options...
Stu Posted April 23, 2022 Share Posted April 23, 2022 Used to used them on the TL1000S The only issue I had was the rear would slide a little when giving it loads! This was solved by running a slightly higher pressure of 38psi as apposed to 36psi Apart from that they worked well Quote Link to comment Share on other sites More sharing options...
Troy Posted April 23, 2022 Author Share Posted April 23, 2022 (edited) 24 minutes ago, Stu said: Used to used them on the TL1000S The only issue I had was the rear would slide a little when giving it loads! This was solved by running a slightly higher pressure of 38psi as apposed to 36psi Apart from that they worked well My owners manual says 42 at the rear and 36 at the front…. Guessing this should be ok then?! Edited April 23, 2022 by Troy Quote Link to comment Share on other sites More sharing options...
Stu Posted April 23, 2022 Share Posted April 23, 2022 1 hour ago, Troy said: My owners manual says 42 at the rear and 36 at the front…. Guessing this should be ok then?! Probably It was 36 front and rear on the TL! Quote Link to comment Share on other sites More sharing options...
