markb Posted October 22, 2022 Posted October 22, 2022 Hi I'm a newbie rider. I did my CBT in 2021, but just bought and started riding in September 2022. I bought myself a new Honda CB125F. For the most part, I am really enjoying riding. I do still seem to stall a few more times than I would like and also feel my slow speed control is still quite basic, but improving over a little each time I ride out. I have one particular issue I wanted to reach out to see if anyone can help pinpoint possible causes. I have just done over 300 miles on my bike since I bought it new, around 6 weeks ago. For the first 150 miles or so, I had no issues of note with my grip on the throttle. I have found however that each subsequent ride I've been out over the last few weeks, my right hand (glove) seems to be slipping more and not feeling as tight a grip on the throttle as I remember in the beginning. I've developed a few techniques to help, but I'm finding losing grip is especially affecting me in having full control at slow speeds and in moving from a standstill. Since starting out in September, I have been using RST CE textile summer gloves (https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/366257). I would have thought that summer gloves would have offered the best grip being made from a thin, lightweight material. Is my problem likely to be glove related or could it be related to the motorbike throttle sleeve and why would I be finding I'm losing grip after doing so few miles? Most of my trips are usually between 20-30 miles so I would have thought that would be classed as short distance and not enough to be the main cause. Appreciate the views of this community? Quote
Gerontious Posted October 23, 2022 Posted October 23, 2022 (edited) If you have big hands perhaps consider adding grip puppies. these make the grips a little larger, but much more easy to grip as they are made from neoprene and have a textured surface that is unaffected by anything. wet or cold. whatever. inexpensive. at circa £13. https://tinyurl.com/5n7b4ux4 Even if you don't have large hands, I would still suggest you try them, as with anything different.. you just adjust. Just to add, I do have large hands and so holding the original grips, well, I sometimes describe its like holding a pencil in each hand. Also, some grips might be heavily textured but the type of plastic they use can be very... slippy. Add all these together and. I can't be doing with it. So.. for years now grip puppies have been my first update. I ordered a pair when I bought my current bike and fitted them as soon as I got it home a week or so later. Edited October 23, 2022 by Gerontious Quote
onesea Posted October 23, 2022 Posted October 23, 2022 Another vote for grip puppies, although I would say cheaper copies are available: https://www.ebay.co.uk/itm/2-X-Motorcycle-Motorbike-Anti-Vibration-Handle-Bar-Foam-Slip-Over-Grips-UK/284911303988?_trkparms=amclksrc=ITM&aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=20200818143230&meid=79fd5d3e62ff416b9525ad81529cddd6&pid=101224&rk=2&rkt=5&sd=325327768899&itm=284911303988&pmt=1&noa=1&pg=2047675&algv=DefaultOrganicWeb&brand=Unbranded&_trksid=p2047675.c101224.m-1&pageci=d5b9d4d0-f4d5-44ea-a1e9-3e821ac8a165&redirect=mobile when it comes to fitting them if you have compressor or SUP pump blowing them on is easiest way to fit.. Quote
Blackholesun Posted October 23, 2022 Posted October 23, 2022 I got some leather gloves and find the grip much better also may be worth having a look at the grip make sure it’s on tight enough Quote
