Turbodave Posted January 19, 2023 Share Posted January 19, 2023 Hi guys, I was fitting new indicators to a 2020 Bullit Hero 125 coz the both rear ones were damaged. I replaced the rear right-hand one ,the front right flashed but the back didn't,so I swapped the wires on the rear , great the right side works perfectly. Did the same on the left ,the front one flashes but the rear didn't so I swapped the rear wires around and Oh! The front one doesn't flash anymore. "Maybe this left rear is faulty" so I take another new indicator and wire it to the back left, no joy, switch the wires over, no joy. I check the right-hand side again,damn, it's not working. I pull and check all fuses,all ok. I check ,taillight,brake light,horn all still working,I start the bike,battery still strong. It was LED indicators already on the bike so I don't think I need to change a relay coz I'm installing new LED indicators. What could be wrong? Quote Link to comment Share on other sites More sharing options...
hawkeye Posted January 22, 2023 Share Posted January 22, 2023 Probably a bad, just get a length of wire, touch it to the socket where the bulb is then on the earth terminal on the battery. Also make sure all the bulbs are the same wattage. 1 Quote Link to comment Share on other sites More sharing options...
Turbodave Posted February 2, 2023 Author Share Posted February 2, 2023 Thanks Hawkeye , I've got them all working , the new indicator I was trying to fit on the back left was faulty. I just fitted another new one and all was working. 1 Quote Link to comment Share on other sites More sharing options...
hawkeye Posted February 2, 2023 Share Posted February 2, 2023 Good to hear, electrics can be a PITA sometimes. Quote Link to comment Share on other sites More sharing options...
