Guest Posted August 13, 2008 Posted August 13, 2008 Anyone tell us how the plug caps come off on the above bike,I have the electrical connection undone just need to know how the plug top comes off to get at the plugs Oh and remind me not to get involved servicing a sports bike near enough stripped the damm bike just to get to the plugs cheers Quote
Stu Posted August 13, 2008 Posted August 13, 2008 pull them Gary they will be in tight they need a good yank Quote
Guest Posted August 13, 2008 Posted August 13, 2008 Cheers Stu,i assumed that was the case but there in good n tight dint want to bust em Quote
Guest Posted August 14, 2008 Posted August 14, 2008 just give 'em a good old tug! Yeah...use your tugging hand......that'll get 'em out.....Know what you mean tho about stripping the bike down just to change the plugs....... Quote
Guest Posted August 14, 2008 Posted August 14, 2008 All done bloomin headstock bearings were a pig couldnt drift them off the bottom stem bearing ended up in a vice till they cracked then it was easy,a little tip for installing the bearing outer shells into the headstock leave them in the freezer over night then run as fast as you can down the street open garage door drop them three times hit thumb with hammer job done Quote
