bigup Posted August 13, 2008 Posted August 13, 2008 http://img528.imageshack.us/img528/600/frontstand14005498603uy0.jpglink: http://www.ghostbikes.com/pp/ACCESSORIE ... Stand.htmlany good for a CBR125? Quote
Guest philgale Posted August 13, 2008 Posted August 13, 2008 i need a paddock stand, might order one of themim sure it would be ok for a 125, order one adn if its not ill give you a tenner for it Quote
bigup Posted August 14, 2008 Author Posted August 14, 2008 i need a paddock stand, might order one of themim sure it would be ok for a 125, order one adn if its not ill give you a tenner for it they based in Preston, so i would probably pick up, to save on postage as i work relatively near bywould i need bobbins aswell for it? Quote
Korben Posted August 14, 2008 Posted August 14, 2008 No Bigup, bobbins are not needed mate.It's a universal one that the swingarm sits on. See the two black pads at the top. Basically you slide those under the swingarm and the weight is taken by those as you lift the bike up. Quote
bigup Posted August 14, 2008 Author Posted August 14, 2008 No Bigup, bobbins are not needed mate.It's a universal one that the swingarm sits on. See the two black pads at the top. Basically you slide those under the swingarm and the weight is taken by those as you lift the bike up. thanks mate Quote
handyandy24 Posted August 14, 2008 Posted August 14, 2008 i mite get one too. ive jus bought a haynes manual. i need to save money so am thinking of living in the shed for a few months learning about bikes Quote
handyandy24 Posted August 14, 2008 Posted August 14, 2008 do you think that thing cud take a zx7r? looks a bit flimsy Quote
Korben Posted August 14, 2008 Posted August 14, 2008 I have something a bit like that which lifts a Hornet happily. If you are worried drop em an email asking what the max weight is. I doubt you would have a problem. Quote
