yama69 Posted August 23, 2023 Posted August 23, 2023 Okay so i have been having this problem lately with my yamaha yzfr 125 2008. The problem is that when im driving sometimes the bike losses power for a second and then goes back to normal no perforamance changes, almost like if the brakes were stuck, it doesnt matter if its hot or not but it happens at random times every once in a while. Does anyone know what could the problem be? Quote
Ian Frog Posted August 23, 2023 Posted August 23, 2023 First off I would check the wiring harness as it passes round the steering head of the frame and investigate any damage. Secondly it's always worth checking that the tank breather is not blocked (if its safe to stop next time it happens open the filler cap and listen for air being sucked in). There will be lot's of other possibilities but those are where I personally would start. Good luck and don't forget to share the results when you get it sorted it might help someone else. Cheers Ian 1 Quote
RideWithStyles Posted August 23, 2023 Posted August 23, 2023 Second motion on Frog. Not unlikely but Im less inclined with the breather as it seems more random, sudden to appear and just as quickly disappear. if it was the breather, generally it's woukd be enough to completely stop drive for more than afew sec , it would more likly vacuum its line dry to a stop and wait until the engine stopped and pressure is reduced and try start the engine again. depends on if owt else happens that you might not notice at first, are all the dash lights fine when it happens etc? Battery, are the cables really fastened properly? cheak other bolts round the chassic like ground / earth wires. Fuel pump connector, Give any connections you see a good push in. 1 Quote
yama69 Posted August 23, 2023 Author Posted August 23, 2023 47 minutes ago, Ian Frog said: First off I would check the wiring harness as it passes round the steering head of the frame and investigate any damage. Secondly it's always worth checking that the tank breather is not blocked (if its safe to stop next time it happens open the filler cap and listen for air being sucked in). There will be lot's of other possibilities but those are where I personally would start. Good luck and don't forget to share the results when you get it sorted it might help someone else. Cheers Ian Okay thank you very much for this information i will check tomorrow. Quote
yama69 Posted August 23, 2023 Author Posted August 23, 2023 20 minutes ago, RideWithStyles said: Second motion on Frog. Not unlikely but Im less inclined with the breather as it seems more random, sudden to appear and just as quickly disappear. if it was the breather, generally it's woukd be enough to completely stop drive for more than afew sec , it would more likly vacuum its line dry to a stop and wait until the engine stopped and pressure is reduced and try start the engine again. depends on if owt else happens that you might not notice at first, are all the dash lights fine when it happens etc? Battery, are the cables really fastened properly? cheak other bolts round the chassic like ground / earth wires. Fuel pump connector, Give any connections you see a good push in. 20 minutes ago, RideWithStyles said: Second motion on Frog. Not unlikely but Im less inclined with the breather as it seems more random, sudden to appear and just as quickly disappear. if it was the breather, generally it's woukd be enough to completely stop drive for more than afew sec , it would more likly vacuum its line dry to a stop and wait until the engine stopped and pressure is reduced and try start the engine again. depends on if owt else happens that you might not notice at first, are all the dash lights fine when it happens etc? Battery, are the cables really fastened properly? cheak other bolts round the chassic like ground / earth wires. Fuel pump connector, Give any connections you see a good push in. I will give that a try thank you. No none of the lights come on it just happens. If it helps you to know sometimes the electricity in the bike is not working right for example when i washed it last time the gauge turned off mid ride and then it was back to normal. So do u think that it has something to do with the electricity? Quote
RideWithStyles Posted August 23, 2023 Posted August 23, 2023 With the fuel one in that manner is less likely the sensor itself but the wires from it or connector from the harness. yes electrical, harness/connectors. Whith the bike cold and id disconnect the battery while you do this. Gently separate any electrical connector blocks properly you see and have a little look at both ends... they should be clean (no furr, colours or deformation etc) and un damaged, if so positively reconnect, go through each one you can see. The dash connection will be a bad to get to but that might play buggers with the bike too. 1 Quote
Mississippi Bullfrog Posted August 23, 2023 Posted August 23, 2023 This often turns out to be a bad battery connection, most often on the earth side. Clean them up paying particular care with the terminals and where the earth strap connects to the frame. 1 Quote
