MV Agusta’s LXP Orioli is powered by a 931cc triple.
MV Agusta’s LXP Orioli is powered by a 931cc triple. (MV Agusta/)
MV Agusta’s LXP Orioli adventure-touring class finally surfaced in its final form at EICMA 2023. The whole project has been vastly revised since KTM took control of the historical Varese, Italy-based make. Gone is the Lucky Explorer name reminiscent of the Cagiva Elefant that challenged the Paris-Dakar, replaced with a name that recognizes Italian rally champ Edi Orioli. And, in line with KTM’s new plans for MV Agusta, the 5.5 version powered by a twin-cylinder engine derived from the Benelli 502 has been scrapped.
The new LXP Orioli is powered by the latest MV Agusta triple, a liquid-cooled 931cc DOHC engine designed and developed by Chief Project Engineer Brian Gillen. This 81mm bore and 60.2mm stroke has been fully refined to Euro 5+ emission standards and now delivers 124 hp at 10,000 rpm with 75.2 lb.-ft. of peak torque at 7,000 rpm. Numbers that confirm this new MV Agusta three is both powerful and flexible, perfect at home on an upper-class adventure model.
Electronics informed by an advanced six-axis inertial platform that interfaces with the ECU to ensure performance and safety with four dedicated riding modes: Urban, Touring, Off-Road, and Custom All Terrain. Traction control comes in five levels: two street, two specifically for off-road, and one for rain. Engine-braking action is selectable over two levels. Cornering ABS has been specifically tuned to apply proper braking control both with road and knobby tires, and the system includes a Rear Wheel Lift-up Mitigation function.
Related: New MV Agusta Range Revealed
Hints of the now discarded Lucky Explorer name are still seen in the LXP Orioli’s graphics.
Hints of the now discarded Lucky Explorer name are still seen in the LXP Orioli’s graphics. (MV Agusta/)
Infotainment and Bluetooth functions are controlled via a 7-inch TFT dash. MV Agusta’s Ride App offers a navigation system and a Mobisat geolocation anti-theft system. Cruise control is standard.
An upper steel-tubing trellis frame integrates a full double-cradle lower section, and chassis components are top-quality by Sachs. A 48mm fork and a link-actuated gas-charged rear shock absorber are both fully adjustable and offer 8.3 inches (210mm) of wheel travel at both ends. Wheelbase is a longish 63.4 inches and steering geometry is an undisclosed rake that uses a 4.6-inch trail. Seat height is adjustable between 34.3 and 33.5 inches while ground clearance is a more than adequate 9.1 inches.
Braking is handled by four-piston Brembo Stylema calipers matched to twin 320mm rotors. At the rear, a 245mm disc is squeezed by a twin-piston caliper.
Only 500 examples of the LXP Orioli will be available.
Only 500 examples of the LXP Orioli will be available. (MV Agusta/)
Right now, the mighty MV Agusta LXP Orioli is planned for a 500-unit limited production run. Pricing is TBA.
2024 MV Agusta LXP Orioli Specs
MSRP: TBA
Engine: DOHC, liquid-cooled triple; 4 valves/cyl.
Displacement: 931cc
Bore x Stroke: 81 x 60.2mm
Compression Ratio: 13.4:1
Claimed Horsepower: 124 hp @ 10,000 rpm
Claimed Torque: 75.2 lb.-ft. @ 7,000 rpm
Fuel System: Fuel injection w/ 47mm Mikuni throttle bodies, ride-by-wire
Clutch: Wet, multiplate; hydraulic actuation
Frame: High-tensile steel double cradle
Front Suspension: 48mm Sachs USD fork, fully adjustable; 8.3 in travel
Rear Suspension: Sachs monoshock, fully adjustable; 8.3 in. travel
Front Brake: Brembo 4-piston Stylema calipers, dual 320mm discs w/ ABS
Rear Brake: 2-piston caliper, 245mm disc w/ ABS
Wheels, Front/Rear: Spoked, tubeless; 21 x 2.15 in. / 18 x 4.0 in.
Tires, Front/Rear: 90/90-21 / 150/70-18
Rake/Trail: TBA/4.6 in.
Wheelbase: 63.4 in.
Ground Clearance: 9.1 in.
Seat Height: 33.5/34.3 in.
Fuel Capacity: 5.3 gal.
Claimed Dry Weight: 485 lb.
Contact: mvagusta.com
