shellnjustin Posted June 8, 2024 Posted June 8, 2024 Hi my sons bike honda cbf 125 starter motor spinning  but not starting any help please  Quote
Old-codger Posted June 9, 2024 Posted June 9, 2024 A bit more info would help ie year, mileage was it running ok the last time it was used. Check basics first as Nick said has it got petrol has it a fuel tap and is it turned on. Is the kill swith turned off. Is the side stand down so it wouldnt start unless the clutch lever is in. How old is the battery and is it fully charged. Is the spark plug in a decent condition and you have a decent spark. Are the battery connections tight. Quote
KiwiBob Posted June 9, 2024 Posted June 9, 2024 9 hours ago, shellnjustin said: Hi my sons bike honda cbf 125 starter motor spinning  but not starting any help please  You say starter motor spinning .. Is it turning the engine over? Or is it just the starter motor spinning? Quote
husoi Posted June 9, 2024 Posted June 9, 2024 Sounds like the starter sprocket is stuck. Being the case, you have to remove the starter and give it a good clean. Check for oil leaks and hopefully doesn't need any seal replaced. Â Obviously with the little information you have given this is a wild guess. 1 Quote
