The hustler Posted October 28, 2024 Posted October 28, 2024 Hi I seem to have a problem with my neutral light not working I’ve changed the switch and still no light ? Quote
The hustler Posted October 28, 2024 Author Posted October 28, 2024 1 minute ago, The hustler said: Hi I seem to have a problem with my neutral light not working I’ve changed the switch and still no light ? It is a Yamaha ybr 125 plus the ignition has been swapped for a aftermarket one Quote
RideWithStyles Posted October 28, 2024 Posted October 28, 2024 Either wiring/connection or the sensor. Quote
husoi Posted October 28, 2024 Posted October 28, 2024 Agree with @RideWithStyles Time to get the multimeter out and check for continuity on wiring. Or check for the 12v if you don't want to unplug the battery 1 Quote
The hustler Posted October 28, 2024 Author Posted October 28, 2024 19 minutes ago, RideWithStyles said: Either wiring/connection or the sensor. I’ve changed the sensor for a new one Quote
The hustler Posted October 28, 2024 Author Posted October 28, 2024 Just now, The hustler said: I’ve changed the sensor for a new one Will this fail an mot? Quote
RideWithStyles Posted October 28, 2024 Posted October 28, 2024 Other than the wiring or a fuse. the sensor needs a pick up to read, is it being able to see/read each other? Its needs to be close. most likely it’s gunked full of chain lube or the pick up has come off? 1 Quote
The hustler Posted October 28, 2024 Author Posted October 28, 2024 17 minutes ago, RideWithStyles said: Other than the wiring or a fuse. the sensor needs a pick up to read, is it being able to see/read each other? Its needs to be close. most likely it’s gunked full of chain lube or the pick up has come off? Quote
Mississippi Bullfrog Posted October 29, 2024 Posted October 29, 2024 Are you sure the light itself is working? Quote
husoi Posted October 29, 2024 Posted October 29, 2024 5 minutes ago, Mississippi Bullfrog said: Are you sure the light itself is working? One would assume it's the first check Quote
Mississippi Bullfrog Posted October 29, 2024 Posted October 29, 2024 5 minutes ago, husoi said: One would assume it's the first check When it comes to anything with wheels I never assume the obvious has been checked. A mate had a problem with his bike and spent a small fortune figuring out why he was getting random loss of power. The dealership had it back and forth and could find nothing wrong with the engine, electronics or transmission. Turned out the glue on his heated grip had failed. 1 3 1 Quote
Capt Sisko Posted October 29, 2024 Posted October 29, 2024 On 28/10/2024 at 09:14, The hustler said: Hi I seem to have a problem with my neutral light not working I’ve changed the switch and still no light ? Is this a selecting neutral or just the light not showing when you are in neutral problem? Quote
