acemastr Posted October 16, 2010 Share Posted October 16, 2010 Started the bike at lunch yesterday to hear a very loud ticking from the engine, it's been making a ticking noise for a while but was very quiet and i assumed it was the cam chain tensioner. Bike shop picked it up from work and i got a lift home, "definitely your cam chain tensioner" was what i was told upon pickup and this morning. So they sold me one... I fit it... still a loud ticking... They want to charge 3-4 hours labour to pull the engine apart and see what it is, which i can't afford at £50 an hour. CBR600FV 1997, just ticked onto 27200KM so...just under 17k miles. I do know that the valve clearances were due at 26k km, which haven't been done, but i can't imagine this would cause a loud ticking suddenly one lunch time.Does anyone have any ideas? I'm seriously desperate Quote Link to comment Share on other sites More sharing options...
Stu Posted October 16, 2010 Share Posted October 16, 2010 just because its ticking it doesnt mean its fudged! So you havent destroyed YET!!!You need to know where the noise is coming from top bottom left right clutch casing rocker cover etc etc if i was you i would strip the fairings and tank off maybe even the air box suspend the tank so you can run the bike but still get in and listen for the sound Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted October 16, 2010 Share Posted October 16, 2010 you can use a length of wood against different places round the engine and place your ear to it you will hear any nasty noises transmited down wood place it around cam cover barrels cam chain area if you can reach it the alternator clutch.it might help you work out what area it is ticking in Quote Link to comment Share on other sites More sharing options...
acemastr Posted October 16, 2010 Author Share Posted October 16, 2010 It's definitely top end, but unfortunately event he screwdriver to the ear on the engine doesn't tell me where it's coming from Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted October 16, 2010 Share Posted October 16, 2010 it could be a cam chain guide stuck or broken up then allowing chain to whip about a bit might need to get to top of engine and remove cam cover to check out whats going on in there Quote Link to comment Share on other sites More sharing options...
Danny-B- Posted October 16, 2010 Share Posted October 16, 2010 Is it a brand new hydrolic CCT ?perhaps the actual chain needs to be replaced ? Quote Link to comment Share on other sites More sharing options...
acemastr Posted October 18, 2010 Author Share Posted October 18, 2010 I may see about taking the rockercover off at some point and just taking a look, see if i can clearly see a problem in there. It's a very definite tick, increases with revs, doesn't go away at any rev range, although i'm not going to rev it too high, if it drops a valve the engines buggered. I can't pinpoint if it's coming from a particular cylinder, I can't actually hear the tick through a screwdriver at all, literally no ticking sound whatsoever, just the hum of the engine and clutch noise. It does however seem noisier on the right side, it could possibly be that the cam chain blade/guides have worn so much that the tensioner is no longer able to push the blade into the cam chain itself and isn't tensioning.Anymore suggestions greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Stu Posted October 18, 2010 Share Posted October 18, 2010 when was the last oil change? ive known old oil make an engine noisey!! Quote Link to comment Share on other sites More sharing options...
acemastr Posted October 18, 2010 Author Share Posted October 18, 2010 3000-4000 miles ago or so Quote Link to comment Share on other sites More sharing options...
