mackemforever Posted March 18, 2011 Share Posted March 18, 2011 Now I apologise for asking stupid questions but I'm a newbie when it comes to doing any work on bikes.I'm currently doing up my old Varadero 125 so it will actually pass an MOT and I can sell the bugger and I've run into a lack of knowledge!I've removed the brake callipers, stripped them right down, cleaned them and replaced the brake pads, but now that I've come to putting them back on the bike I realised that I have no idea how I'd go about bleeding the system after I've replaced the brake fluid.Would somebody please be able to give me some guidance as to how I would go about doing that.Thanks. Quote Link to comment Share on other sites More sharing options...
rennie Posted March 18, 2011 Share Posted March 18, 2011 Have a look in the guides section I'm sure there is a thread in there Quote Link to comment Share on other sites More sharing options...
rennie Posted March 18, 2011 Share Posted March 18, 2011 http://www.themotorbikeforum.co.uk/view ... 27&t=13141there you go I thought I'd written one Quote Link to comment Share on other sites More sharing options...
mackemforever Posted March 18, 2011 Author Share Posted March 18, 2011 http://www.themotorbikeforum.co.uk/viewtopic.php?f=27&t=13141there you go I thought I'd written one Ta very much for that.One question though, I made an error in my first post, I've only removed the front brake calliper, would I only need to bleed the front brake or are both brakes linked into one system? Quote Link to comment Share on other sites More sharing options...
rennie Posted March 18, 2011 Share Posted March 18, 2011 I would think they are seperate!some Hondas have linked brakesbut it's unusualWhat bike? Quote Link to comment Share on other sites More sharing options...
mackemforever Posted March 18, 2011 Author Share Posted March 18, 2011 I would think they are seperate!some Hondas have linked brakesbut it's unusualWhat bike? Its a 52 plate Varadero 125. I've had a google but can't find anything about it. I would have a close look at the bike to see if its got 2 brake fluid resevoirs but the bike is in Bristol and I'm in Lancaster right now! Quote Link to comment Share on other sites More sharing options...
rennie Posted March 18, 2011 Share Posted March 18, 2011 I'm 99% sure they're not linked!tends to be the bigger bikes pan european/blackbird/ vfr.Yours is only a single caliper on the front?Really easy to do! Quote Link to comment Share on other sites More sharing options...
griff488 Posted March 18, 2011 Share Posted March 18, 2011 Has the bike got ABS? If so theres a chance they'll be linked Quote Link to comment Share on other sites More sharing options...
Stu Posted March 18, 2011 Share Posted March 18, 2011 There not linked you will have a single line running to the caliper pretty easy to bleed You want an assistant to make life easy Quote Link to comment Share on other sites More sharing options...
mackemforever Posted March 18, 2011 Author Share Posted March 18, 2011 Ok, I just thought I should check about the linking as I know the Varadero 1000 has linked brakes. Quote Link to comment Share on other sites More sharing options...
