Xbandito Posted August 15, 2011 Share Posted August 15, 2011 On both my bikes, the Derbi Terra and the baby Vara, go into 1st, 2nd but then wont go into 3rd, let alone any higher. I have to roll off the throttle and keep trying till it goes in, sometimes I have to do it without the clutch. The annoying thing is the Vara is only 5 days old (got knocked over when two days old) but the Derbi is now 10 months old (and this could be another thing to add to the list of faults) but what is happening ?. Some biker lads yesterday said something about the "spring", others said the clutch needs adjusting.....confused...please help, I look like such a noob going up the road with the bike reving like hell, trying to get it into gear.. Quote Link to comment Share on other sites More sharing options...
Fozzie Posted August 15, 2011 Share Posted August 15, 2011 When does the clutch bite?If you pop it into first and the revs drop it might be dragging. So details on how far you let the lever out before it bites would help As if you let it out a few mm and its going then you just need to adjust the clutch cable done using the adjusters at the lever and at the engine. Use youtube if you dont know how to adjust a clutch, its literally a 2 minute job. Quote Link to comment Share on other sites More sharing options...
megawatt Posted August 15, 2011 Share Posted August 15, 2011 Gear shift return spring is usually at the back of the clutch casing. Need a picture or drawing to confirm? Quote Link to comment Share on other sites More sharing options...
Tango Posted August 15, 2011 Share Posted August 15, 2011 Check your chain tension too. If it's too loose you can get gear shift issues. And as Fozzie says....if the clutch is dragging you'll have probs also.....Good LuckBob Quote Link to comment Share on other sites More sharing options...
