toon83 Posted August 15, 2011 Share Posted August 15, 2011 i suffer real bad with nerves and i have my mod 2 on wed but i feel like its in 10 mins any tips for calming down??? Quote Link to comment Share on other sites More sharing options...
OhJay Posted August 15, 2011 Share Posted August 15, 2011 Now or on your test? Quote Link to comment Share on other sites More sharing options...
toon83 Posted August 15, 2011 Author Share Posted August 15, 2011 Now or on your test? both Quote Link to comment Share on other sites More sharing options...
olidavey Posted August 15, 2011 Share Posted August 15, 2011 Now - couple of shots of vodka. Test - Kalms tablets or bachs herbal remedy.I took kalms tablets and found they really helped. Quote Link to comment Share on other sites More sharing options...
Mawsley Posted August 15, 2011 Share Posted August 15, 2011 i suffer real bad with nerves and i have my mod 2 on wed but i feel like its in 10 mins any tips for calming down??? Sex releases endorphines which have a calming effect - so maybe popping into the toilet at the test centre could produce beneficial results. Quote Link to comment Share on other sites More sharing options...
sparkeh9 Posted August 15, 2011 Share Posted August 15, 2011 i suffer real bad with nerves and i have my mod 2 on wed but i feel like its in 10 mins any tips for calming down??? Sex releases endorphines which have a calming effect - so maybe popping into the toilet at the test centre could produce beneficial results. LOL Quote Link to comment Share on other sites More sharing options...
toon83 Posted August 15, 2011 Author Share Posted August 15, 2011 i suffer real bad with nerves and i have my mod 2 on wed but i feel like its in 10 mins any tips for calming down??? Sex releases endorphines which have a calming effect - so maybe popping into the toilet at the test centre could produce beneficial results. wow didn't see that one coming Quote Link to comment Share on other sites More sharing options...
toon83 Posted August 15, 2011 Author Share Posted August 15, 2011 Now - couple of shots of vodka. Test - Kalms tablets or bachs herbal remedy.I took kalms tablets and found they really helped. where from? Quote Link to comment Share on other sites More sharing options...
Reaper Posted August 15, 2011 Share Posted August 15, 2011 Sex releases endorphines which have a calming effect - so maybe popping into the toilet at the test centre could produce beneficial results. I feel a bit nervous right now,i`ll be back in a couple of minutes. Quote Link to comment Share on other sites More sharing options...
Mawsley Posted August 15, 2011 Share Posted August 15, 2011 i suffer real bad with nerves and i have my mod 2 on wed but i feel like its in 10 mins any tips for calming down??? Sex releases endorphines which have a calming effect - so maybe popping into the toilet at the test centre could produce beneficial results. wow didn't see that one coming That's what she said... Quote Link to comment Share on other sites More sharing options...
olidavey Posted August 15, 2011 Share Posted August 15, 2011 Now - couple of shots of vodka. Test - Kalms tablets or bachs herbal remedy.I took kalms tablets and found they really helped. where from? bootshttp://www.boots.com/en/Kalms-Tablets-B ... -_1013968/ Quote Link to comment Share on other sites More sharing options...
mealexme Posted August 15, 2011 Share Posted August 15, 2011 you guys are so helpful haha. sex and alcohol? i don't think alcohol will help at all for a motorbike test, especially on a public road.sex on the other hand, if the instructor is fit then... Quote Link to comment Share on other sites More sharing options...
Ingah Posted August 15, 2011 Share Posted August 15, 2011 I think we forgot rock and roll (as alcohol is technically a drug, right? ) Quote Link to comment Share on other sites More sharing options...
Mhocking Posted August 16, 2011 Share Posted August 16, 2011 Good luck for tomorrow! Quote Link to comment Share on other sites More sharing options...
toon83 Posted August 16, 2011 Author Share Posted August 16, 2011 Good luck for tomorrow! Quote Link to comment Share on other sites More sharing options...
OhJay Posted August 16, 2011 Share Posted August 16, 2011 Talk yourself through everything while you're on the ride. Say everything out loud, what you're looking at, what you see, when you're changing down, look through the turn... Give yourself a running commentary inside your lid, makes your thoughts much clearer.Have you tried chewing gum? A tip I was given that really helped me with an anxiety problem. Stops your mouth going dry, prevents you clenching your jaw or grinding your teeth, and I also noticed when I was getting more stressed I started to chew harder and faster so when I noticed that if I consciously slowed my chewing down it had a noticeable effect on the tension.Flap your arms like you're doing the birdie song when you're on the bike. Forces you to keep your arms relaxed, try flapping at the elbow with straight or tense arms. And it usually makes me giggle as well, what the hell must I look like riding down the road flapping like a chicken? Good luck Quote Link to comment Share on other sites More sharing options...
toon83 Posted August 16, 2011 Author Share Posted August 16, 2011 Talk yourself through everything while you're on the ride. Say everything out loud, what you're looking at, what you see, when you're changing down, look through the turn... Give yourself a running commentary inside your lid, makes your thoughts much clearer.Have you tried chewing gum? A tip I was given that really helped me with an anxiety problem. Stops your mouth going dry, prevents you clenching your jaw or grinding your teeth, and I also noticed when I was getting more stressed I started to chew harder and faster so when I noticed that if I consciously slowed my chewing down it had a noticeable effect on the tension.Flap your arms like you're doing the birdie song when you're on the bike. Forces you to keep your arms relaxed, try flapping at the elbow with straight or tense arms. And it usually makes me giggle as well, what the hell must I look like riding down the road flapping like a chicken? Good luck some good advice i will try it although i might look like a crazy person tell you what i will do the chicken dance if i pass Quote Link to comment Share on other sites More sharing options...
OhJay Posted August 16, 2011 Share Posted August 16, 2011 You do feel like a right prat doing it but your arms are relaxed and just try being tense while you're giggling Quote Link to comment Share on other sites More sharing options...
toon83 Posted August 17, 2011 Author Share Posted August 17, 2011 You do feel like a right prat doing it but your arms are relaxed and just try being tense while you're giggling wow iv been up since 6am and im feeling the pressure already i thought id do the chicken dance this morning i did feel a bit calmer plus my 6 month old daughter thought i was really funny and she joined in if anyone would of seen us they would of died a 28yr old man and a baby chicken dancing to bring me the horizon my nerves are going mental but i feel confident i can do well today. Quote Link to comment Share on other sites More sharing options...
OhJay Posted August 17, 2011 Share Posted August 17, 2011 Good luck Quote Link to comment Share on other sites More sharing options...
Theboyparker Posted August 17, 2011 Share Posted August 17, 2011 Good luck Quote Link to comment Share on other sites More sharing options...
Mawsley Posted August 17, 2011 Share Posted August 17, 2011 So, Vodka, pills, a chicken dance and then a 5-minute ham shandy in the toilet. How can it possibly go wrong? Quote Link to comment Share on other sites More sharing options...
Mawsley Posted August 17, 2011 Share Posted August 17, 2011 ...and good luck Quote Link to comment Share on other sites More sharing options...
toon83 Posted August 17, 2011 Author Share Posted August 17, 2011 So, Vodka, pills, a chicken dance and then a 5-minute ham shandy in the toilet. How can it possibly go wrong? it did i failed to see the traffic lights change in time so i got a major fault Quote Link to comment Share on other sites More sharing options...
