GARYJL Posted November 21, 2011 Share Posted November 21, 2011 (edited) Im in the process of buying a house and im thinking about convertingthe heating from gas to oil and thought I would see if anyone knew roughlywhat it would cost ? Its a two bedroom house and it already has raidiatorsin all of the rooms so its only the boiler that needs swapped and connectedto the mains. Edited November 21, 2011 by GARYJL Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted November 21, 2011 Share Posted November 21, 2011 dont forget you need to include the cost of the oil tank and a location for it Quote Link to comment Share on other sites More sharing options...
Guest Posted November 21, 2011 Share Posted November 21, 2011 Really, gas to oil?The cost of installation of the new boiler, the boiler its self, the installation of the oil tank and everything else included probably is not going to save you money! That and oil is getting steadily more expensive?If your trying to save money go ahead and make your house far better insulated, anything from triple glazing, cavity walls, loft insulation etc etc, hell chuck in some PV or solar thermal panels .Seriously, its not something I'd consider, oil to gas then yes I'd agree... Quote Link to comment Share on other sites More sharing options...
GARYJL Posted November 21, 2011 Author Share Posted November 21, 2011 Meant oil to gas Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted November 21, 2011 Share Posted November 21, 2011 cost would vary greatly on boiler choice personally i would go for a condensing combi boiler slightly more cost to start but far more efficent Quote Link to comment Share on other sites More sharing options...
Theboyparker Posted November 21, 2011 Share Posted November 21, 2011 Have u got gas in the area? Are there gas mains that could have a service taken off them in the road or footpath? Or are you taking bottled gas?You need to consider the cost of installing a new service, boiler and any other associated pipe work needed.We use oil for heating and hot water, and the cost is creeping up every year. Quote Link to comment Share on other sites More sharing options...
Nogin Posted November 21, 2011 Share Posted November 21, 2011 Rads are fine, Look at a gas combi boiler (condensing)If its bottled gas forget it, its not worth it.I looked into it and we were looking at £10K at least. Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted November 22, 2011 Share Posted November 22, 2011 2.4K Quote Link to comment Share on other sites More sharing options...
GARYJL Posted November 22, 2011 Author Share Posted November 22, 2011 Anyone know if you can have a gas boiler outside like oil ?I think you have to have direct access to an outside wall and it would bea nightmare getting somewhere thats not going to look crap. Quote Link to comment Share on other sites More sharing options...
Theboyparker Posted November 22, 2011 Share Posted November 22, 2011 Yes I think u can plus you'd need access to the meter as well. Have u not got an airing cupboard upstairs? They can usually fit in there too Quote Link to comment Share on other sites More sharing options...
GARYJL Posted November 22, 2011 Author Share Posted November 22, 2011 Yes I think u can plus you'd need access to the meter as well. Have u not got an airing cupboard upstairs? They can usually fit in there too Its in a really bad place, if everything goes ahead and we get the house im going torefit the bathroom in the coming months so I might swap things round and have thegas burner stuck randomly to the wall for now and then box it in later.Ideally outside would be best. Quote Link to comment Share on other sites More sharing options...
Theboyparker Posted November 22, 2011 Share Posted November 22, 2011 Best thing to do is contact ur local gas supplier. Have a look on the NationalGrid website. I work for them but I don't know everything. There should be a section on there about who to contact etc... If I get chance tomorrow I'll have a look for a link but like I said I dont know everything. Or try the ofgem website there the watch dog and there should be some info on there Quote Link to comment Share on other sites More sharing options...
nigelwood1 Posted November 23, 2011 Share Posted November 23, 2011 Have you got loft space????Stick it in your loft and no its not a good idea to put it outside. Quote Link to comment Share on other sites More sharing options...
Susieque Posted November 23, 2011 Share Posted November 23, 2011 Anyone know if you can have a gas boiler outside like oil ?I think you have to have direct access to an outside wall and it would bea nightmare getting somewhere thats not going to look crap. I know very little about boilers but where I used to live we had our boiler (oil fired cos there was no gas in the village) backed onto an outside wall & the whole thing kind of went through the wall, if that makes sense. Outside there was a removeable panel and maintenance work to the boiler could be done from outside I think Quote Link to comment Share on other sites More sharing options...
Guest Posted November 23, 2011 Share Posted November 23, 2011 Oil to gas makes sense.Current boilers can go in a lot of places, due to less heat loss and smaller size, I'm not sure if you can get external gas boilers but worth looking around. Make sure you get a decent installer, there are so many problems you can experience with a cowboy its unreal. Do not go British/Scottish gas if you can help it too . Combi boilers are very common but really does depend on the type of demands you'll be asking for (1 shower or 3 showers at the same time etc?) and what kind of in comming flow rate and pressure you have on your cold tap. As said going to LPG (bottled gas) would be pretty pointless also. Quote Link to comment Share on other sites More sharing options...
