bluenose Posted May 22, 2012 Share Posted May 22, 2012 Hi all noticed this morning that my front right indicator isn't working and the back one is flashing really fast,the left ones are fine. I checked the front one and the bulb is fine any ideas? Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted May 22, 2012 Share Posted May 22, 2012 i woul change the bulb first off as they can look fine and not be,hen check the earth on the indicator,if yours has 2 wires coming out into main loom then you need to check you have got a live and earth feed Quote Link to comment Share on other sites More sharing options...
Stu Posted May 22, 2012 Share Posted May 22, 2012 also check the contacts in the bulb holder these are prone to going rusty and no contact Quote Link to comment Share on other sites More sharing options...
Colin the Bear Posted May 28, 2012 Share Posted May 28, 2012 Swap bulbs around, if the fault moves with the bulb, sorted Quote Link to comment Share on other sites More sharing options...
pointblank0 Posted June 9, 2012 Share Posted June 9, 2012 Swap bulbs around, if the fault moves with the bulb, sorted As he said. Do this first as it's free! A rapidly flashing indicator is an interuption in the circuit, be it blown bulb or other. If bulb isn't blown, then sand down the connectors in the lamp, probably a poor connection. No need to go searching around all the wiring, it will be restricted to that bulb and/or housing of that bulb. Fear not!PS, indicators do tend to collect water Quote Link to comment Share on other sites More sharing options...
