techno Posted July 7, 2012 Share Posted July 7, 2012 A friend at work has a 1999 gxsr 6 it was his track bike but he's put it back on road problem he has the lights drain the battery, no problem at all if he never uses lights but as not long after putting them on nowt.Battery is charging and holding a charge and he has a new reg/rec fitted. Quote Link to comment Share on other sites More sharing options...
megawatt Posted July 7, 2012 Share Posted July 7, 2012 Alternator fault not getting enough volts to battery when lights are on? or dodgy battery? Quote Link to comment Share on other sites More sharing options...
Tango Posted July 7, 2012 Share Posted July 7, 2012 He needs to check the voltage at the battery when the engine is running.......he may have a duff stator....or a wiring fault in the charging circuit.... Quote Link to comment Share on other sites More sharing options...
rennie Posted July 8, 2012 Share Posted July 8, 2012 Sounds like a short in the lighting circuit to me!He needs to spend some time with a Volt Meter! Quote Link to comment Share on other sites More sharing options...
