Karimura Posted October 10, 2012 Share Posted October 10, 2012 Hi pitstop crew, attempting to find one, looked on like their offical motorcycle parts, and ebay also some sites that sell parts but cannot find a complete gasket set for a engine or exhaust sort of thing. I think the gaskets (complete one) covers the exhaust aswell but If not i'll buy 1 for engine and 1 for exhaustBut all I find is either expensive single items or complete ones for 1980's cgs :/I have 06 one so giving up here guys so hopefully you can step in and know where to look or something, cheers -reason i need one as engine is using lots of oil but no spileages or burning, it's like got a hole inside where it drips down and burns off inside engine- also my exhaust rattles lol Quote Link to comment Share on other sites More sharing options...
Stu Posted October 10, 2012 Share Posted October 10, 2012 so your doing a full rebuild because its using some oil how much oil is it using over how many miles? Quote Link to comment Share on other sites More sharing options...
Karimura Posted October 10, 2012 Author Share Posted October 10, 2012 so your doing a full rebuild because its using some oil how much oil is it using over how many miles? Got told to look in engine you need to replace them bits so think its true dunno Ummm, I used a full bottle of halfords for around 2months, brought 5 litres one now put some in last week and had my mod 1 training last weekend and they put in half a litre as said it was dry!.Had many theories, the oil's cream so means water is inside it, and like i stated about burning hole, but also where i ran around for a week without oil it pooped the engine.I use it around 8 miles every 2 days as i cycle to work the other day, but if i lazy that week it's all 5 days, so 8 miles per day Quote Link to comment Share on other sites More sharing options...
pointblank0 Posted October 14, 2012 Share Posted October 14, 2012 Full sets are quite expensive, and you will probably use less than half of them really, as you will probably come across the problem before you remove everything. You will probably be able to get away with a top end gasket set, strip the engine down to the pistons, and hopefully you would have come across the guilty gasket. It's probably the barrel gasket, which is a pain int he arse to get to, but it's a cheap fix.Exhaust gaskets are only about 20 - 50p each and probably wont come in a full gasket set. You can get them off wemoto and ebay. Quote Link to comment Share on other sites More sharing options...
Karimura Posted October 18, 2012 Author Share Posted October 18, 2012 Full sets are quite expensive, and you will probably use less than half of them really, as you will probably come across the problem before you remove everything. You will probably be able to get away with a top end gasket set, strip the engine down to the pistons, and hopefully you would have come across the guilty gasket. It's probably the barrel gasket, which is a pain int he arse to get to, but it's a cheap fix.Exhaust gaskets are only about 20 - 50p each and probably wont come in a full gasket set. You can get them off wemoto and ebay. Ohh thanks! yeah I got email listing the gaskets at 5/10 quid each, but some are full and just 16 quid, always confused, but I just buy most likely ones that need replacing Quote Link to comment Share on other sites More sharing options...
pointblank0 Posted October 19, 2012 Share Posted October 19, 2012 Let us know how you get on mate. Quote Link to comment Share on other sites More sharing options...
Karimura Posted October 19, 2012 Author Share Posted October 19, 2012 Will do!, Got to fix eletricals, think its worn selnoid not altantor thing, rear wheel went flat at work so pushed that to mot place,and oil leaking in my engine somewhere : obusy weekend! Quote Link to comment Share on other sites More sharing options...
pointblank0 Posted October 20, 2012 Share Posted October 20, 2012 Bikes tend to need loads of maintenance. I repair something on mine pretty much every weekend, usually small jobs, but they need doing. Funny enough, I sprang a leak in my cooling system yesterday, so my nice relaxing Sunday will be spent in my cold garage grazing my knuckles and swearing a lot! Never mind, that should be all for another week! Quote Link to comment Share on other sites More sharing options...
pointblank0 Posted October 25, 2012 Share Posted October 25, 2012 I forgot how amusing and great fun motorbikes really are! My slight coolant leak ended up with my radiator completely emptying it's guts over the road on my way home from work today. Lucky my new radiator arrived this morning, but still, tomorrow morning will be spent in a big winter coat, a flask of tea and a tin of rolling backey, in my cold garage, nursing a hangover.Rock and roll! Quote Link to comment Share on other sites More sharing options...
