jarrodstrachan Posted September 21, 2013 Share Posted September 21, 2013 So I've had my YBR 125 '12 Model for a little over a month now, with 700 miles clocked on it, I bought it used, and have started tarting it up to look new again, hoping to have it looked showroom by the time I come to sell it. Everything's great, apart from, Neutral is very... flaky. Going from first to second, alot of the time it ends up in neutral, I can deal with that, but the main problem I discovered this morning while on a 80 mile round trip on lots of national speed limit roads, the bike slipped into neutral, from FIFTH, twice, without me touching the clutch or the gear lever.I'm thinking an oil change is needed, as it hasn't had any change since it was purchased by the previous owner over a year ago. I cleaned the spark plug but I'm already planning on buying a new one anyway.Is my diagnosis correct? CheersAny queries just ask Quote Link to comment Share on other sites More sharing options...
Tango Posted September 21, 2013 Share Posted September 21, 2013 When you say it slips into neutral do you mean a false neutral between 4th & 5th......or the main neutral (between 1st & 2nd)?False neutrals can be caused by either not enough positive pressure on the gear lever when changing gear......or possibly an incorrectly tensioned chain....which is causing the drive train to snatch a bit......and possibly oil, but not necessarily...... Welcome to TMBF by the way.......make your way over to the Newbies and say hello to the gang on here when you can..... Quote Link to comment Share on other sites More sharing options...
jarrodstrachan Posted September 21, 2013 Author Share Posted September 21, 2013 When you say it slips into neutral do you mean a false neutral between 4th & 5th......or the main neutral (between 1st & 2nd)?False neutrals can be caused by either not enough positive pressure on the gear lever when changing gear......or possibly an incorrectly tensioned chain....which is causing the drive train to snatch a bit......and possibly oil, but not necessarily...... Welcome to TMBF by the way.......make your way over to the Newbies and say hello to the gang on here when you can..... Well, I've had two different kinds, I've had a slip where, the neutral light is OFF but the bike isn't in gear, so I knocked it back down to fourth, then back up to fifth, that fixed that.Another time I was going from third to fourth, and it slipped into neutral WITH the neutral light ON, same remedy, knock it down and back up Quote Link to comment Share on other sites More sharing options...
Tango Posted September 21, 2013 Share Posted September 21, 2013 LOL....just realised that you've already done the Newbie bit.......DOH..... Anyway.......it may be that you just need to give the gear shift a bit more welly when changing up.......and sometimes pre-loading the lever will help with the upshifts too...... Quote Link to comment Share on other sites More sharing options...
Lumor_uk Posted September 21, 2013 Share Posted September 21, 2013 My bike will jump down from 2nd to neutral if I haven't engaged 2nd properly usually because I'm trying to do it quickly wearing steel toe cap boots (can't feel the gear shifter). Quote Link to comment Share on other sites More sharing options...
jarrodstrachan Posted September 22, 2013 Author Share Posted September 22, 2013 My bike will jump down from 2nd to neutral if I haven't engaged 2nd properly usually because I'm trying to do it quickly wearing steel toe cap boots (can't feel the gear shifter). Hmm I gues that could be the problem, I'm using reinforced toe caps, so I'm relying on the feeling from my ankle rather than the actual gear lever, I'll test tomorrow to see if I'm being a bit tame on the gear changes, but I'm also changing the oil aswell and see if that helps.Cheers for the help so far guys Quote Link to comment Share on other sites More sharing options...
jarrodstrachan Posted September 22, 2013 Author Share Posted September 22, 2013 So today I spent my time, with my brother in law who knows much more about bikes and working on them than I do, cleaning the bike, wirebrushing the metal parts and spraying it new, and I was telling him about my problem with the gears, and he checked the chain, and said it was waaaay to slack, so he tightneed it up and then I went out and test it, it felt like a different bike, the engine breaking wasn't nearly as severe, I could actually glide a bit while in gear, I liked it alot more. Then while cleaning the nuts and screws, I accidentaly unscrewed the oil cap screw, and lo and behold, a litre of oil fell out, onto the garage floor, jet black. So we went up halfords and got some Castrol Power 10W40 and put that in, and I'm glad to say, everything working perfectly. Feels like a different bike, it even seemed to handle better but I think that's because I feel more confident cornering knowing that it wont slip into neutral mid-corner.Much happier with it Quote Link to comment Share on other sites More sharing options...
CGD217 Posted September 22, 2013 Share Posted September 22, 2013 Yep tightening the chain made a big difference on my YBR too Quote Link to comment Share on other sites More sharing options...
Guest Posted September 27, 2013 Share Posted September 27, 2013 i used to get the same thing from 1st to 2nd gear when im wearing my work boots but you'll soon get used to it Quote Link to comment Share on other sites More sharing options...
mealexme Posted September 29, 2013 Share Posted September 29, 2013 yea, unfortunately its a known problem with the YBR. oil changes help, but it probably won't fix it completely. There isn't really anything you can do about it so try not to worry about it too much if it happens again Quote Link to comment Share on other sites More sharing options...
Tango Posted September 29, 2013 Share Posted September 29, 2013 Erm....seems like tensioning the chain correctly and changing the oil has sorted the problem out guys..... Quote Link to comment Share on other sites More sharing options...
