Harrydh3 Posted February 2, 2014 Share Posted February 2, 2014 Hello there guys.I've been away for a while since my YZF got pinched but I'm back! What I've done is bought a 1981 gp 100 and have ideas of making a retro racer sort of thing.I need to ride to work on it most of the time aswell which doesn't help but it should be ok for the now.On the list of things to do to begin with...Oil changeCarb Strip and cleanFork seals,Both brake light switches,Secure indicators and headlight,Petseal the tank,New sparking plug,New chain and sprockets,New air filter,New brake shoes,New cable set,New wiring harness,New gips,On the dreamy probably overly optimistic list of things to do in the near future...Powder coat the frame and swinging arm silver,Powder coat the tank and side panels racing green,Re chrome the forks,Re chrome the wheels,New side stand,New tyres and tubes,New rear light and indicators,New bars,Modern switch gear,Rear sets,Expansion chamber exhaust,Flat slide carb,Café racer tail section,I'll update with Pics when I get on with a few bits, tomorrow after work. Please feel free to point out any jobs that need doing to a newly bought s*** heap before regular riding is to occour. I will update this post as I go on.Cheers, Harry. Quote Link to comment Share on other sites More sharing options...
Harrydh3 Posted February 4, 2014 Author Share Posted February 4, 2014 Got some bits done today, I had the carb cover and carb off so I can blast the cover back to silver as it has been painted black and I need to chuck my carb in the ultrasonics tank.Pulled the vast majority of the old loom outAnd whipped the head off for blasting alsoIm unsure as to wether to run it without the airbox and a direct filter and swap the 97 main jet for a 100 and put colder plug in....Watch this space, also, im after a fairing from a tz350 if anyone happens to have one knocking about Quote Link to comment Share on other sites More sharing options...
rennie Posted February 4, 2014 Share Posted February 4, 2014 welcome back! Quote Link to comment Share on other sites More sharing options...
Harrydh3 Posted February 6, 2014 Author Share Posted February 6, 2014 Had a couple of set backs and the bike will need to be used to commute sooner than I thought, put it all back together again and low and behold, it doesn't bloody work, revs till 6 then dies.So i'm going to get a new condenser and points at the weekend, do the timing and hope for progress, so I can continue with the few more bits I need to do before I can start pissing my money away on cosmetics. Honestly will get some pictures up at some point. And cheers fella, its good to be back on two wheels again! Quote Link to comment Share on other sites More sharing options...
Hunter Posted February 7, 2014 Share Posted February 7, 2014 Keep going fella Quote Link to comment Share on other sites More sharing options...
Tango Posted February 7, 2014 Share Posted February 7, 2014 Yeah....good to see you back Harry......and I hope the bike gets sorted..... Shout out if you need any thoughts or advice..... Quote Link to comment Share on other sites More sharing options...
