Adam Posted April 27, 2014 Share Posted April 27, 2014 As the title suggests my sump bolt has seized I could not for the life of me get it undone. I stopped in the end because the bolt is starting to show signs of wear and I don't want it to become impossible to remove. Anyone got any ideas? Thank youuuu Quote Link to comment Share on other sites More sharing options...
cockercas Posted April 27, 2014 Share Posted April 27, 2014 Gental Heat.. Give it a gental tap with a mallet. Is the spanner slipping of the bolt?Is the plug on the bottom or the side of the sump? Quote Link to comment Share on other sites More sharing options...
Adam Posted April 27, 2014 Author Share Posted April 27, 2014 What can I use to heat it? I just have your run of the mill household items.. It's underneath, and no it's not slipping the socket is getting stuck on the bolt because the edges are losing their shape when I try to turn it. I've tried hitting the ratchet whilst it's on the bolt but that didn't help either. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted April 27, 2014 Share Posted April 27, 2014 you want a proper 6 sided socket on it for starters adam that way it cant round off the bolt head try running engine for 5 mins then carefully see if bolt will loosen off as alloy expands faster than the steel bolt and might mean you can break the seal on it unless last person to service it has bodged it in Quote Link to comment Share on other sites More sharing options...
Tiggie Posted April 27, 2014 Share Posted April 27, 2014 I use a set of irwin bolt grips like these for any really stubborn bolts . they bite into the bolt as you loosen it, expensive for what they are but well worth imo http://www.dieselbike.net/extraction/Bolt%20Grip2.JPG Quote Link to comment Share on other sites More sharing options...
Adam Posted April 27, 2014 Author Share Posted April 27, 2014 It's not rounded off as such Steve I'll attach a picture of what I mean, it was the best way to describe it. The socket I've been using is six sided. I'll try that with warming the engine before trying to remove it, but I'm going to order a new sump plug before I (try) remove this one. Quote Link to comment Share on other sites More sharing options...
cockercas Posted April 27, 2014 Share Posted April 27, 2014 Use a spanner insted. see if you can clamp the spanner onto the bolt. If you cant get a clamp on use a car jack and a bit of wood to trap the spanner on then try hitting the spanner to shock it out. Failing that if ita rounding get a file and file the bolt head down abit and knock a old socket on there and try a solid bar and not a rachet with a extension on for leaverage. You shouldnt need the extension as it shouldnt be tat tight. Were are you? Quote Link to comment Share on other sites More sharing options...
Stu Posted April 27, 2014 Share Posted April 27, 2014 Personally I would stick to a socket as spanners tend to be 12 point and not 6 plus with the angled head you could end up not putting even pressure on it If you are using a cheap socket then I would buy a decent one and a nice strong arm breaker bar I have had to use a strong arm on a couple of sump plugs before and one swift jolt gets them off As already said run the motor for a while to warm things up a bit Quote Link to comment Share on other sites More sharing options...
littlecat Posted April 27, 2014 Share Posted April 27, 2014 breaker bar is an absolute essential in my toolkit, cant undo bugger all without it Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted April 27, 2014 Share Posted April 27, 2014 Hi it sounds like its been well over tightened all you need to do is crush up a copper washer for the sump bolt. As already suggested make sure you've got a snug fitting socket and a power bar and just double check your turning it in right direction you might laugh be it been done believe me. If its really stuck apply heat around the bolt not on the bolt itself. Best of luck Quote Link to comment Share on other sites More sharing options...
fq-craigus Posted April 27, 2014 Share Posted April 27, 2014 Ring spanner and hit it, sump plugs are sometimes done up exsessivly tight and go with a crack as some people think they need to do them up ft when you don't Quote Link to comment Share on other sites More sharing options...
GaryJM Posted April 27, 2014 Share Posted April 27, 2014 Also why torque wrenches are such a must have tool as well. IMV you need two to cover up to about 220 nm. No more over tightened nuts or bolts then. Quote Link to comment Share on other sites More sharing options...
