Mr Fro Posted May 8, 2014 Share Posted May 8, 2014 Has anyone got one of these? This is the sort of thing I was thinking of but don't know if they'd be much good unless they can be rigged up so some sort of logger. Quote Link to comment Share on other sites More sharing options...
Stu Posted May 8, 2014 Share Posted May 8, 2014 I have been looking in to these myself and as you say you need a logger that also logs RPM and throttle position if your going to be tuning something like a power commander although just a basic logger would do the job if you have time to play with the fueling after all if its just a power commander its just plug it in and make changes if its carbs then its removing the carbs every time! Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted May 8, 2014 Author Share Posted May 8, 2014 if its carbs then its removing the carbs every time!Precisamundo.Don't think I fancy holding WOT all the way up the rev range while staring at the display - I've absolutely no idea how rig up a logger aside from filming it. Quote Link to comment Share on other sites More sharing options...
Stu Posted May 8, 2014 Share Posted May 8, 2014 I've absolutely no idea how rig up a logger aside from filming it. Hmmmm you now have me thinking viewtopic.php?f=83&t=52546 Quote Link to comment Share on other sites More sharing options...
