I have an intermittent horn problem (sometimes it works, sometimes not) and I'll bet it is a faulty connection somewhere in one of the crimp connectors that I used to build the relay circuit.
I hate barrel crimp connectors - especially the straight-through ones (that look like a tube) - sometimes it doesn't matter how hard you crimp the damn things, even with the correct crimp tool and the correct size of connector for the wire you're using, sometimes the wire just falls straight out.
What alternatives are there? Apart from (a) chock blocks - you can't always get chock blocks into small spaces and (b) soldering - soldering is a pain the arse!
these
http://www.narva.com.au/sitebuilder/products/medium/1061/non-insulated-blade.png
crimped with the right tool then a drop of solder on the terminal too finished off with some heat shrink :)
these
Looks good, what are they called?
They used to be called spade connectors (male & female).....have a wander round Maplins and see if you can find them in there..... 8-)
non insulated connectors
but you MUST get the proper crimp tool
the factory will use these on most connections on the loom too so any new ones can look stock ;-)
I wish they sold these in halfords! All you can get in Halfords are absolute shite connectors.
They do Mate!
http://www.halfords.com/webapp/wcs/stor ... yId_255229
Another possible alternative could be "Wire Glue"
Never tried myself, but looks interesting...
Do what I do and twist the wires together, tape up and tell yourself you'll sort it tomorrow for months on end
Twist wires together, solder and tape up. Best connection by a long way.
better still, heat shrink the connection. will outlast the rest of the wiring.
get yourself a decent soldering iron though, not the shite that i have...
