dragolith Posted June 7, 2014 Share Posted June 7, 2014 Hey all,I just got new brake pads fitted, the rear wheel turns freely but the front is hard to turn as the pads rub. After some riding I assume the pads will wear in? Or should it run freely like the rear?Thanks. Quote Link to comment Share on other sites More sharing options...
Stu Posted June 7, 2014 Share Posted June 7, 2014 sounds like your pistons are sticking a bit probably could do with a strip and clean Quote Link to comment Share on other sites More sharing options...
dragolith Posted June 8, 2014 Author Share Posted June 8, 2014 Wouldnt that be done during pad replacement? Quote Link to comment Share on other sites More sharing options...
Tango Posted June 8, 2014 Share Posted June 8, 2014 Not necessarily......ideally when you have the old pads out give the brake a pump to push the pistons out a bit further.....then clean the pistons as much as you can and give them a light smear of red rubber grease before pushing them back into the caliper. Then pump the brake a few times to make sure all the pistons are moving together. Then fit the new pads with a touch of copper grease on the guide pins and the back of the new pads..... Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted June 8, 2014 Share Posted June 8, 2014 Did you fit them yourself or was it done at a shop? If you did it yourself follow Tango's advice to rectify. If not, then take it back to the shop and get them to sort it. Sticking pads will ware out quickly, and could possibly warp the disc. Quote Link to comment Share on other sites More sharing options...
dragolith Posted June 8, 2014 Author Share Posted June 8, 2014 I took it to a local garage, ill call tomorrow to ask them, because I have no clue how to deal with brakes, or most things for that matter! Quote Link to comment Share on other sites More sharing options...
