denz90wolf Posted March 2, 2015 Share Posted March 2, 2015 Hello , i have a lot of oil on my wheel rims ( not sure if that is the right term ) but i using wd40 very slightly but its taking the paint off my wheels . its basically oil off me chain think i been putting to much on lol Is there a better way of getting it off maybe with a foam spary or something like that? Quote Link to comment Share on other sites More sharing options...
Joeman Posted March 2, 2015 Share Posted March 2, 2015 Wd40 won't remove paint... Unless someone has painted your wheels with the wrong paint!!Are you sure its not brake fluid?? Brake fluid will strip paint. Quote Link to comment Share on other sites More sharing options...
Stu Posted March 2, 2015 Share Posted March 2, 2015 Quote Link to comment Share on other sites More sharing options...
denz90wolf Posted March 2, 2015 Author Share Posted March 2, 2015 deffo not brake fuild its chain lube mainly and when i wipe it with a rag the wd40 does take it off slightly . Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted March 3, 2015 Share Posted March 3, 2015 Detergent mixed with hot water and a stiff (ish) brush should do it.If the paint is flaking off, then this will be due to a poor application in the first place or, as stated, you have some kind of 'stripper' fluid on there. Quote Link to comment Share on other sites More sharing options...
denz90wolf Posted March 4, 2015 Author Share Posted March 4, 2015 my bike is a 14 model honda cbr 125 so luckily it isn't flaking yet lol Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted March 4, 2015 Share Posted March 4, 2015 Hi, It sounds to me like your applying way to much lube or using crap gear. I would suggest you give the chain a good clean and apply a good chain lube. This kit here should do you fine.http://www.ebay.co.uk/itm/WURTH-BRAKE-A ... 4897.l4275All l do to clean my wheel's is to give them a quick wipe with a rag and WD40 Quote Link to comment Share on other sites More sharing options...
