Throttled Posted May 16, 2015 Posted May 16, 2015 (edited) They can weld themselves on to the valve. I am talking about caps like thishttp://www.superforma.co.uk/media/catalog/product/cache/1/image/650x/040ec09b1e35df139433887a97daa66f/g/o/gold_valve_caps__medium__1.jpgI fitted them to both my bikes, I used ACF50 since there is a known issue, but it did not stop them from welding themselves on. So far one was stiff but came off, one had to be cut off, one has come off with the valve so I need a new inner tube and I have one more to try and remove. Edited May 16, 2015 by Throttled Quote
Stu Posted May 16, 2015 Posted May 16, 2015 I have known this for years I found out by my brother doing the same thing Quote
fullscreenaging Posted May 16, 2015 Posted May 16, 2015 Surely they will only weld themselves on if you're not checking your tyre pressures regularly?Or this could happen over winter when not riding. Quote
Throttled Posted May 16, 2015 Author Posted May 16, 2015 Surely they will only weld themselves on if you're not checking your tyre pressures regularly?Or this could happen over winter when not riding. Both bikes are used in bad weather, one more so than the other and both happened in the space of a month. Quote
Stu Posted May 16, 2015 Posted May 16, 2015 yeah it doesnt take long for these to become stiff!! I think its a reaction with the different metals that causes it Quote
Throttled Posted May 16, 2015 Author Posted May 16, 2015 I think that what happened is that I got lazy squirting a bit of ACF 50 into the valves before I put them back on and then they welded. All four in one go after no issues for over a year. They are being replaced with plastic ones, 12 for 99p off eBay. Quote
Tankbag Posted May 16, 2015 Posted May 16, 2015 yeah it doesnt take long for these to become stiff!! I think its a reaction with the different metals that causes itDissimilar metal corrosion, these must love the valve stem though ! Quote
rice-pudding Posted May 17, 2015 Posted May 17, 2015 I think these cheap caps are aluminium and they react with the brass values and "weld" together. Don't buy crap! I did once and had to get brand new valves fitted on my car tyres Quote
fq-craigus Posted May 17, 2015 Posted May 17, 2015 I have metal caps on my car, but they are stainless with o-ring seals, i had some cheap novelty type r ones on my old car and they fused to the valves (didnt check tyres for ages) had to get a tyre shop to replace the valves in the end Quote
Guest Posted May 18, 2015 Posted May 18, 2015 yup it's a reaction between the metals. Simple solution, once a week pop them off give them a blow and then pop them back on. It'll stop them from getting stuck. Quote
rice-pudding Posted May 18, 2015 Posted May 18, 2015 I'd rather spend the couple of extra squid and buy steel ones, saves time and money in the long run. I have nice yellow ones on, designed for HGV's. No more crap gets in there Quote
