seanycozzie16v Posted March 31, 2016 Share Posted March 31, 2016 So was on the dual carriageway nicely tootling along at 60 when the bike just lost all power and died. This was at full throttle. Let the throttle off and started pumping it to get it to go again. It eventually did and power came back but it was spluttering and everything. It's as if it was being starved of fuel. Did it again at a junction. Started back up again but was very hesitant at revving at idle. Like a delay. Pulled the plugs out. They are new btw and they are like a browny white with no blackness to then at all? Quote Link to comment Share on other sites More sharing options...
seanycozzie16v Posted March 31, 2016 Author Share Posted March 31, 2016 Round town though it runs quite nicely. Not running full throttle though. Has a very rough idle also. Sometimes it will idle but most of the time the revs drop very slowly and it just cuts out Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted March 31, 2016 Share Posted March 31, 2016 you need to find out if you have got a fuel starvation problem ride the bike and as it cuts out and stops open the fuel cap listen for it hissing or the sound of air rushing in it could be a blocked breather hole in the fuel cap Quote Link to comment Share on other sites More sharing options...
seanycozzie16v Posted March 31, 2016 Author Share Posted March 31, 2016 Tried that no hissing or.anything Quote Link to comment Share on other sites More sharing options...
Tango Posted March 31, 2016 Share Posted March 31, 2016 Does sound like a blocked tank breather to me too........and the idle mixture screw sounds like it could do with a tweak...... Quote Link to comment Share on other sites More sharing options...
seanycozzie16v Posted March 31, 2016 Author Share Posted March 31, 2016 Screwing out the mixture screw makes it richer correct? Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted April 1, 2016 Share Posted April 1, 2016 check how many turns the mixture screw is out by counting it as you screw it in then bring it back out about 1 1/2 to 1 3/4 turns and see how it is Quote Link to comment Share on other sites More sharing options...
fredc Posted April 1, 2016 Share Posted April 1, 2016 check how many turns the mixture screw is out by counting it as you screw it in then bring it back out about 1 1/2 to 1 3/4 turns and see how it is don't screw it in tight, you'll damage the tip Quote Link to comment Share on other sites More sharing options...
seanycozzie16v Posted April 2, 2016 Author Share Posted April 2, 2016 found the issue. pulled the float bowl off and found a bit of dirt lying at the bottom of the bowl. adjusted the float height again and also added a inline filter to catch any dirt from the tank. seems to be ok now. but i find i have to run a tiny bit of choke all the time to keep it running Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted April 2, 2016 Share Posted April 2, 2016 then it isnt right it must be running to lean (not enough fuel ) Quote Link to comment Share on other sites More sharing options...
seanycozzie16v Posted April 2, 2016 Author Share Posted April 2, 2016 mixture screw? tried that makes no difference to the running. usually you would hear the revs rise when screwing it out? i get nothing Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted April 2, 2016 Share Posted April 2, 2016 Have you cleaned it? Get some spray carb cleaner (£6-7 from Halfords), take all the jets, screws, tubes, floats etc out of the carb and spray it in all the knooks and crannies and through any holes and such. Quote Link to comment Share on other sites More sharing options...
seanycozzie16v Posted April 2, 2016 Author Share Posted April 2, 2016 been taken apart and cleaned numerous times. i've been thinking. i fancy upping the size of the jets to the next size. main jet and pilot jet. they are only a couple of quid on ebay so should i? the pilot jet in this mikuni bds26 carb is a #20 and the main jet is a 102.5. i'm really at my wits end here Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted April 3, 2016 Share Posted April 3, 2016 Are they the correct sizes in there at the mo? I'd be tempted to get a fresh set of jets and screws in case the old ones are damaged (easily done) and sonicate the carb body. Changing the jet sizes only works if you know everything else is functioning correctly. From what you've said, it sounds like you still have a blockage. Quote Link to comment Share on other sites More sharing options...
