FZ6 broken down, please help if you can
Foxy Stoat seeks Pig
Like this, if you aren't sure what Joe means - the washer should have little 'teeth' that engage with corresponding teeth on the output shaft, preventing the washer from rotating separately from the shaft.
http://www.sportbikes.net/forums/attachments/zzr-600/228233d1389988570-2007-zzr-600-front-sprocket-20131230_170823.jpg
Post up a picture just with the cog and washer fitted not the nut then we can see how it is going together
*disclaimer: RantMachine don't know shit*
Well, if the washer is engaged with the splines, the nut is properly torqued, and at least one side of the washer is folded over the nut nice and snug, I can't see it being a problem! :thumb:
All the above in place. My worry was the amount of thread still unused on the nut
Went out for a few miles very close to home (didn't fancy a long push home :D ) took it steady didn't go above 40mph. Very paranoid about any noise and have zero confidence in bike, well maybe 5% now.
Got home and took the cover off and the nut is still as tight as when I left although I think I need to invest in a torque wrench. I'm probably going to give it a run out at the weekend. I'm not taking it to work tomorrow or Friday. Am also going to buy a spare nut and washer and keep it under seat. Will probably check the nut every day now for a while. :D
Despite all this it felt great to be on the bike again!! Thanks all for your help. I do hope that is my problem sorted now.
