Can you take out the starter motor, strip it down ready for cleaning, if unsure use your mobile phone to take photos of each step, clean the inside of the starter motor ,don't use any water , and take the carbon deposit off the armature, I will get you a video off You tube to help you, while your doing that ,just put the battery on charge, also send me a picture of your Multimeter and I can send you some instructions for it :thumb:
http://i.imgur.com/eJkfQ6s.jpg
I know how to clean the starter motor so will pull it out and clean it again. Thank you
Use one of your card nail files to clean the carbon off :wink:
Haha. I do not have those things. Just taking pictures.
What does the armature and windings look like on the inside, as long as those 2 carbons clean up alright and the armature is ok ,might be back in business, but it looks like previous owner has mistreated it :shock:
Could you clean up the end of the carbon where it touches the armature just for better contact, with the edge of a razor blade, is the carbon on the left fixed tightly to the connecting wire :wink:
http://i.imgur.com/jYzflcv.jpg
quote="spanner"]Could you clean up the end of the carbon where it touches the armature just for better contact, with the edge of a razor blade, is the carbon on the left fixed tightly to the connecting wire :wink:
Have you cleaned the copper part of the armature its hard to tell with the light, a match box edge could work with that :wink:
You are a genius Spanner. Still trying to stop the bleeding. Will take more photos in a min.
(Now having a weird question ask to me...been ask out on a date. I am not a normal girl, who the feck would date a girl that has her bike in bits in her living room floor lol).
You can only give it a go CW, but watch your step if you don't already know the person, these days the parameters have moved , and parents don't dress their girls up in pink ,be yourself and they can take or leave it :thumb:
Posted (edited)
http://i.imgur.com/EefHTKB.jpg
Might be worth putting it all back together, and giving it a go, it can only be the starter motor now, there is a 2pin diode but your neutral switch runs through that and the neutral looks like its working , if you have got any jumper cables you could attach them to the battery pos to the starter cable nut on top and neg to the body of the starter motor to see if it spins before you put it back on the bike, it will make you jump if it does spin:)
Edited by ThePhatomfart
