Liveware Problem Posted March 6, 2017 Posted March 6, 2017 Hello, me again!I have a bit of a problem starting my cb600f from cold, I know it's an old bike (W reg) with carbs, but still it seems surprisingly reluctant -Essentially I open the choke, try the electric starter plus some throttle, (can't get it going without some throttle) and it can take several attempts to start, with it seeming to start but then dieing, before finally getting going. Also a few times when stopped at lights I've had it die on me, the revs just dropping off and it dies (no it's not me stalling it ) Any ideas where to start? Quote
Mississippi Bullfrog Posted March 6, 2017 Posted March 6, 2017 What kind of mileage is on it?First thing is the idle setting if it's stalling regularly. But if it's sometimes idling OK and just randomly dying then I'd take a look at the valve clearances.I assume it's pulling cleanly on throttle so it's not a carb issue?I'd also check the battery as a weak battery can cause interesting issues. Quote
ThePhatomfart Posted March 6, 2017 Posted March 6, 2017 Hi , is it a CBR600f or a CB600f you've got, and do you need the manual Quote
TimR Posted March 6, 2017 Posted March 6, 2017 Possibly the choke cable has stretched or starting to break may need adjustment or renewal..Does it idle ok when warm ? Quote
Liveware Problem Posted March 6, 2017 Author Posted March 6, 2017 Sorry it's a cb600f, well spotted Spanner I have the Honda owner's manual if that's what you mean?It has done just under 33k miles, and pulls cleanly on the throttle. It seems to idle ok when warm, but I haven't got much to compare it too! Thanks for the advice, I knew I needed to get it checked out but it is useful to know where to start Quote
ThePhatomfart Posted March 6, 2017 Posted March 6, 2017 Have a look at this LW https://www.dropbox.com/s/x0lrd3lpknmju1g/Honda%20CB600fw.pdf?dl=1 Quote
Liveware Problem Posted March 6, 2017 Author Posted March 6, 2017 Have a look at this LW https://www.dropbox.com/s/x0lrd3lpknmju1g/Honda%20CB600fw.pdf?dl=1 Thanks Spanner, that looks very useful, and also terrifying I've had a look through the service history, I can't find any record of the valve clearances being checked, and the carburettor idle speed was last checked 4 years ago.. Quote
ThePhatomfart Posted March 6, 2017 Posted March 6, 2017 Hi , look through the trouble shooting at the back of the manual, then come back with the problems that are concerning you, I'm sure between your self and everyone on here a result can be effected Quote
Liveware Problem Posted March 6, 2017 Author Posted March 6, 2017 It says: engine starts but then stopsSuggests: improper choke operation carburetor incorrectly adjusted intake pipe leaking improper ignition timing (faulty ignition coil or ignition pulse generator) fuel contaminated I'm guessing fuel contamination is unlikely, it's had at least 2 tank loads from different filling stations.Improper choke operation - by me or a problem with the choke itself?The other 3 sound plausible? Quote
ThePhatomfart Posted March 6, 2017 Posted March 6, 2017 Its always easier to do the simple things first, adjust idle (3-15), check operation of the choke ( might have to take the tank off to see operation of slider bar), air cleaner, check out Section 5, Throttle sensor check out section 17 Quote
