Philmorgs Posted June 19, 2017 Posted June 19, 2017 hello everybody. new to this so please bare with me. i have a 2014 honda cbr125R. had this bike for about 6 months now and never had a single problem. Until yesterday that is. I was riding home from work when a noticed a high pitched whistling noise coming from inside my fuel tank. naturally i went to the internet to try to diagnose this problem and all that i could find was about pressure realizing through the tank lid. so i set to test the theory by putting my spare key in the tank removing the lid and started the bike up . But the noise was still there. please note that noise is only there when engine is on and the fuel pump primes as normal. now the strangest thing that i found is that when i either put my indicators on or full beam the whistle changes from a constant tone to a sort of siren? does anybody have any ideas? cheers guys phil. Quote
TimR Posted June 19, 2017 Posted June 19, 2017 Possible blocked breather but due to hot weather and fuel expansion it is quite common for breathers not to cope and the caps to be displaced under pressure . Quote
Philmorgs Posted June 19, 2017 Author Posted June 19, 2017 so what does that mean for me a trip to the garage? i wasn't sure on whether it was just an electrical fault or not as the noise changed when i indicate?cheers for the reply man Quote
Philmorgs Posted June 19, 2017 Author Posted June 19, 2017 if it is the fuel pump whining what does that mean ? is that normal can i still ride as normal? sorry if I'm being stupid just not very clued up on this type of thing .cheers phil Quote
Stu Posted June 19, 2017 Posted June 19, 2017 It means it's working They all whine to some extent Quote
Philmorgs Posted June 19, 2017 Author Posted June 19, 2017 ahh ok i just assumed because i hadn't heard it before it was going to blow up or something hopefully its only that !! Quote
Baldrick Posted June 19, 2017 Posted June 19, 2017 I had a Z750 that used to do this, especially in hot weather like it is now, It was nothing to worry about, it didn't affect the bike in any way, it was just a bit annoying.it'll be the hot weather. Quote
anilv Posted June 21, 2017 Posted June 21, 2017 Hi Phil,If it didn't make noise before I would get it checked by a workshop, preferably an auth. repair centre as your bike is fairly new.Noise could mean the pump is dirty (needs cleaning) or is on its way out (the bike may start to jerk, worst case leave you stranded).Cleaning the in tank filter is not that difficult but you need to remove the tank. Most bikes now use quick disconnects and you need to know how to disconnect it.good luck!Anilv Quote
anilv Posted June 21, 2017 Posted June 21, 2017 Found thishttp://www.125ccsportsbikes.com/forums/index.php?showtopic=128402And here's one guys take on the problem..http://www.youtube.com/watch?v=AXT04XhnDlE Quote
Philmorgs Posted June 23, 2017 Author Posted June 23, 2017 Thanks for the replies guys. As the tank was getting empty noise got a lot quieter. Put some new fuel in and it's still there but barely noitcible? Possibly was like it before but only noticing because I'm checking? Would you guys leave it now as it seems to be barely noticeable ? Cheers Quote
rennie Posted June 23, 2017 Posted June 23, 2017 I think I'd leave it for a while, see if it gets better or worse Quote
