Foxy Stoat seeks Pig Posted September 17, 2017 Author Share Posted September 17, 2017 I would have stuck (pun intended) to the superglue and be quick method get a screwdriver under it with a bit of WD40 they are usually really flexible and will allow a bit of stretch Unless they are heated grips! Unfortunately they are heated grips Quote Link to comment Share on other sites More sharing options...
Tango Posted September 17, 2017 Share Posted September 17, 2017 See if you can persuade a bit of liquid soap between the grip and the bar..... Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted September 17, 2017 Author Share Posted September 17, 2017 ok I'm going to give it another try after work tomorrow. see if I can create a bit more of a gap to get some wd40 in there. the new one wont be delivered before next weekend anyway so will hold off ordering just yet. Just have to ride this week with an uneven wonky grip. Quote Link to comment Share on other sites More sharing options...
fastbob Posted September 18, 2017 Share Posted September 18, 2017 If you are going to use superglue then you need to be fast and I mean very fast! I have seen many people glue the grips on halfway and also at the same time find that their hands are glued to the grips Yea pretty much my worry. If they are stuck halfway then I'm in a world of s**t, maybe some kind of no more nails type adhesive, should give me a bit longer to slide the grip onto the bar.This is part of the Zap range of specialist super glues available from all good RC model shops. Cure time 30 - 40 seconds . http://i.imgur.com/bGzgbVP.png Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted September 20, 2017 Author Share Posted September 20, 2017 Left hand grip started slipping and rotating yesterday so I've superglued it in place. It's stuck solid for now, if its comes loose again i'm Araldite(ing) the t**t. Will tackle throttle side with some WD at the weekend, see if I can back it off the throttle grip and start over. Quote Link to comment Share on other sites More sharing options...
