LegOverLass Posted December 4, 2017 Posted December 4, 2017 Hiya,Does anyone know if heated handlebar grips would drain the life out of a suzuki intruder vl125 battery?I fitted a trickle charger last week but still not sure how do-able it is.Thanks Quote
Grumpy Old Git Posted December 4, 2017 Posted December 4, 2017 As long as the battery is good and you wire in the grips through a relay (can be powered on only when the ignition is on), there should not be any issue. Quote
SlowBusa Posted December 4, 2017 Posted December 4, 2017 I just make sure I turn mine off when Im a few streets away or a minute or 2 before I turn engine offSo a little charge goes back into battery Its not needed but Its Just to make sure Quote
Chrissb6 Posted December 4, 2017 Posted December 4, 2017 Shouldn't be a problem provided your not sitting at idle for long periods in traffic . Heated grips pull about 4 amps, that's roughly another headlight bulb. I would suggest you connect everything up switch on and then check the voltage across the battery with the engine running, if the reading at the battery is 12.8 volts or more the battery getting a charge. Quote
MR_W Posted December 4, 2017 Posted December 4, 2017 Only time I had an issue was when I swapped a battery and put the connectors on the wrong way round.... Found out the hard way when they didn't warm my hands up. Quote
tPIC Posted December 4, 2017 Posted December 4, 2017 Hiya,Does anyone know if heated handlebar grips would drain the life out of a suzuki intruder vl125 battery?I fitted a trickle charger last week but still not sure how do-able it is.Thanks I'd say worth the risk at this time of year! I've just fitted some to a Honda CRF250L and seems okay so far. Quote
LegOverLass Posted December 12, 2017 Author Posted December 12, 2017 Thanks for all the replies everyone. Been trying to respond for a week but everytime i tried i got the spinning wheel of doom on my phone So far so good! I'll check the voltage too next time its running. Fingers crossed it keeps working. This will be the only thing that prevents Parked motorbike syndrome for me. Quote
MR_W Posted December 12, 2017 Posted December 12, 2017 Thanks for all the replies everyone. Been trying to respond for a week but everytime i tried i got the spinning wheel of doom on my phone So far so good! I'll check the voltage too next time its running. Fingers crossed it keeps working. This will be the only thing that prevents Parked motorbike syndrome for me. I don't want my bike rusting to oblivion so it's tucked up for the winter.That and I do not trust my tyres in the wet and cold. Quote
Hoggs Posted December 12, 2017 Posted December 12, 2017 That and I do not trust my tyres in the wet and cold. Get PR3s Quote
Stu Posted December 12, 2017 Posted December 12, 2017 That and I do not trust my tyres in the wet and cold. Get PR3s Or 4's or even 5's when they come out in the new year Quote
Stocky Posted December 12, 2017 Posted December 12, 2017 The latest range of Oxford heated grips will switch themselves off if you forget, so they can be safely just connected across the battery.I have tested this (unintentionally) several times, and it works a treat.They also have about 6 different heat settings, from just removing the chill all the way to WTF. Quote
SlowBusa Posted December 12, 2017 Posted December 12, 2017 The latest range of Oxford heated grips will switch themselves off if you forget, so they can be safely just connected across the battery.I have tested this (unintentionally) several times, and it works a treat.They also have about 6 different heat settings, from just removing the chill all the way to WTF. I dont trust in this feature on mine,...........they are supposed to shut off if battery gets as low as 12.2V...............thats only "just" enough to crank my engineI think I will carry on being paranoid about turning them off a min or 2 before I turn off engineOf Course some Dickhead can switch them on "for a laugh" as they pass if they are direct to battery Quote
Stu Posted December 12, 2017 Posted December 12, 2017 The latest range of Oxford heated grips will switch themselves off if you forget, so they can be safely just connected across the battery.I have tested this (unintentionally) several times, and it works a treat.They also have about 6 different heat settings, from just removing the chill all the way to WTF. I dont trust in this feature on mine,...........they are supposed to shut off if battery gets as low as 12.2V...............thats only "just" enough to crank my engineI think I will carry on being paranoid about turning them off a min or 2 before I turn off engineOf Course some Dickhead can switch them on "for a laugh" as they pass if they are direct to battery You are being paranoid it does actually work Although mine are wired to a relay! But it's just more for ease rather than to stop the battery going flat Quote
SlowBusa Posted December 12, 2017 Posted December 12, 2017 I think I will test this with my spare battery just to see what voltage it shuts down at and if there is still enough power to start a freezing cold 4 cylinder Quote
Stu Posted December 12, 2017 Posted December 12, 2017 I think I will test this with my spare battery just to see what voltage it shuts down at and if there is still enough power to start a freezing cold 4 cylinder If you have the I believe version 8 controller it should shut off in about a minute or so once it senses that its not charging Quote
SlowBusa Posted December 12, 2017 Posted December 12, 2017 2 year old grips with this controller Bike is in friends garagecant ride it Atm as having to use ice studs on shoes just to walk around here ATM (ice is bad here)A test could help the OP decide so I will test tomorrow Quote
Stu Posted December 12, 2017 Posted December 12, 2017 Yup same as mine you can see the v8 in the left corner Quote
MR_W Posted December 12, 2017 Posted December 12, 2017 The latest range of Oxford heated grips will switch themselves off if you forget, so they can be safely just connected across the battery.I have tested this (unintentionally) several times, and it works a treat.They also have about 6 different heat settings, from just removing the chill all the way to WTF. I quite like the wtf setting. Toasty Quote
SlowBusa Posted December 13, 2017 Posted December 13, 2017 Ok Ive just tested this and the Grips turned themselves off after 6 minGreen "saver" light started flashing at 2 minbattery went down to 12,9v (Li-ion)It Is a version 8 Quote
LegOverLass Posted December 18, 2017 Author Posted December 18, 2017 I think i'll err on the side of paranoid too just because when i was testing them at the very start it completely killed my battery, that was just testing to see if they worked lol Quote
LegOverLass Posted January 22, 2018 Author Posted January 22, 2018 The latest range of Oxford heated grips will switch themselves off if you forget, so they can be safely just connected across the battery.I have tested this (unintentionally) several times, and it works a treat.They also have about 6 different heat settings, from just removing the chill all the way to WTF. I quite like the wtf setting. Toasty Yeah the WTF setting does it for me too no such thing as too hot Quote
