Newwave Posted December 18, 2018 Share Posted December 18, 2018 Anyone know how to upgrade the twin headlights on my 2001 zx7r. I was riding with my mate who has a fireblade and his headlight had a good strong white light, he shot off leaving me with a dull yellow light which was so dangerous couldnt see much of the road. Quote Link to comment Share on other sites More sharing options...
TimR Posted December 18, 2018 Share Posted December 18, 2018 simple way is to change bulb for a new one . bulbs tarnish with age and become dull. or look at nightbreakers etc Quote Link to comment Share on other sites More sharing options...
Tango Posted December 18, 2018 Share Posted December 18, 2018 I've got Night-breakers on my bike and they're pretty bright....... Quote Link to comment Share on other sites More sharing options...
inewham Posted December 29, 2018 Share Posted December 29, 2018 Half the problem with ZX7R headlights is the underspec'ed 5A wiring to the lights and crap dip switch: On mine I wired up a UK headlamp ( 2x 45W incandescent bulbs ) so that the feed to the lights was all 15A cable straight back to the battery and switched by a relay operated from the dip switch. Now both headlamps are on all the time and now its brighter than Euro spec one incandescent / one halogen projector that it came with. Just bypassing the spindly wiring and switch makes one hell of a differenceIf you fit higher rated bulbs, they wont fit properly since one tab is slightly different on the 45W bulbs and if you cut it off to make it fit, the 5A wiring will likely overheat and melt the insulationBTW if you have a projector, it will be a euro spec so the beam pattern is the wrong way around which also wont help. IIRC projectors were never a standard fit for UK but there were so many parallel imports they seem to be quite common.Relays and fat cables for the win Quote Link to comment Share on other sites More sharing options...
