Frigging boiler gone tits up!
Probably the worst time to do it!
Gas?
bugger... whats up with her, is she breathing , have you rung the doctor or 111 ?
Gas?
she's been out with Dynax on the Heinz ?
@Stu Make and issue?
Ideal logic heat15+ not firing no error codes
Tried resetting powering off bled radiators to check for air
has been working today but no go now!
Gas?
I have plenty of that!
Wife doesn't like it :lol:
Heat only boiler, is it getting demand for heat, no error would indicate it thinks everything is fine
Could be 3 way valve not switching or external control
3 port valve is moving when switching between heating and hot water etc
pump circulates but the boiler just doesn't fire up
They are prone to fans, ignition units and sump clogging up if not cleaned but with that you usually hear a gurgling, but if it's displays not changing from, 0 the boiler pcb is either f**ked or it's not getting signal for heat, ie back to external control
Oh dear! Good luck getting someone out to that!
Heating off is fine, it's if you get shafted for the repair price is issue at mo, most plumbers gas fitters still doing repairs.
Is it displaying 0 on display?
Yes showing 0 no burner light
Thats all not sounding good!
I have had the sump changed as it cracked about a year ago and serviced at the same time
I have a guy coming tomorrow
Usually there is a single switch wire to fire up boiler it's first one to the left of mains inlet on boiler panel, it's marked sl1 if that has no voltage it's doing nothing.
Still think it's external, I would pop round but it's a tad out the road.
I have figured out that I have hot water side but not central heating
I shorted the room stat to rule that and still nothing
Sounds like return wire from port valve
Sounds like an easy fix then :lol:
Hopefully that's all it is!
Cheers bender I would sort it myself but I will let this guy do it!
