I have a CG 125 bike made in china CDI model.The push rod of that bike had broken and I think the broken piece stucked in the engine.the engine does not spin.If I detach the sideof the CDI can I take it out.
Guest Richzx6r
It's goingto be a head off job for that
:stupid:
What he said. Also don't try turning the engine over anymore until you have sorted it!
No , I don't think so . Leave it with me and I'll come back to you later this evening . I think you are going to have to take the head and barrel off so order a gasket set off eBay.
Actually it's all coming back to me . You are going to have to take the head and barrel off , definitely .
Guest Richzx6r
Or send it to one of us with a few quid and we will sort it out for you
Look what I found in my scrap collection . Just the one I'm afraid but if it's any use PM me . The bad news is that if , as I suspect , one of the hardened steel ends has come off and gone in your engine , it will do horrible damage if it gets between the teeth of the cam sprocket . Have you tried turning the engine backwards by the way ?
