Dean01982 Posted November 11, 2020 Author Share Posted November 11, 2020 @rennie and @JRHI have just ordered these! Are they a lamp or a bulb https://www.amazon.co.uk/dp/B07QWC31CW/ref=cm_sw_r_cp_apa_fabt1_dlT_YJuQFbV7HEMKH?_encoding=UTF8&psc=1Let us know how you get on with these i could be interested in trying these. A guy has them at work and he says they are spot on Have you had any success with getting these fitted? I can't get the socket to fit.Cheers Quote Link to comment Share on other sites More sharing options...
husoi Posted November 11, 2020 Share Posted November 11, 2020 Let us know how you get on with these i could be interested in trying these. A guy has them at work and he says they are spot on Have you had any success with getting these fitted? I can't get the socket to fit.Cheers Depending on your bike you maybe need to cut off the metal tabs to fit it properly. Quote Link to comment Share on other sites More sharing options...
dynax Posted November 11, 2020 Share Posted November 11, 2020 A guy has them at work and he says they are spot on Have you had any success with getting these fitted? I can't get the socket to fit.Cheers Depending on your bike you maybe need to cut off the metal tabs to fit it properly. Too much of a hassle for me i'm afraid, there should be no need to do this amount of bodgery to get it to fit, it's a no from me Quote Link to comment Share on other sites More sharing options...
Stu Posted November 11, 2020 Share Posted November 11, 2020 Let us know how you get on with these i could be interested in trying these. A guy has them at work and he says they are spot on Have you had any success with getting these fitted? I can't get the socket to fit.Cheers No I'm at work and only got delivery today! Quote Link to comment Share on other sites More sharing options...
Dean01982 Posted November 11, 2020 Author Share Posted November 11, 2020 Thanks for the replies, I managed to get it to fit into the H1 side, left hand side of my fazer 1999, the right side fit perfectly using the supplied socket adapter, but the left been a H1 bulb originally needed some persuasion, the socket that came with the new (bulbs) was way to big so not only did I chop off the lugs I had to cut out a couple of slots so it would marry up, if any one would like a picture then il happily remove it to show you how I did it. Lights look great now there working and the difference is huge. Cheers Quote Link to comment Share on other sites More sharing options...
Dean01982 Posted November 11, 2020 Author Share Posted November 11, 2020 Quote Link to comment Share on other sites More sharing options...
Dean01982 Posted November 11, 2020 Author Share Posted November 11, 2020 Above pictures with led lights in, looks way brighter on person, il get another when its dark Quote Link to comment Share on other sites More sharing options...
Stu Posted November 11, 2020 Share Posted November 11, 2020 I left work at 5 and had them fitted by 1740 Massive difference although the first few pics don't do them justice! First two pics are about a metre away from my garage door with old lamps on low then high beam These are the new LED's on low then high beam And obviously outside on low then high with the new LED's! I wish I had taken some before and afters outside too The difference is huge! Quote Link to comment Share on other sites More sharing options...
Dean01982 Posted November 11, 2020 Author Share Posted November 11, 2020 I left work at 5 and had them fitted by 1740 Massive difference although the first few pics don't do them justice! First two pics are about a metre away from my garage door with old lamps on low then high beam IMG_20201111_171830.jpgIMG_20201111_171846.jpgThese are the new LED's on low then high beamIMG_20201111_173525.jpgIMG_20201111_173532.jpgAnd obviously outside on low then high with the new LED's! IMG_20201111_174010.jpgIMG_20201111_174017.jpgI wish I had taken some before and afters outside too The difference is huge! Tidy work, my issue was the left hand side light was a different bulb to the right. Seem good bulbs tho and hopefully they are fine for an MOT Quote Link to comment Share on other sites More sharing options...
Stu Posted November 11, 2020 Share Posted November 11, 2020 I left work at 5 and had them fitted by 1740 Massive difference although the first few pics don't do them justice! First two pics are about a metre away from my garage door with old lamps on low then high beam IMG_20201111_171830.jpgIMG_20201111_171846.jpgThese are the new LED's on low then high beamIMG_20201111_173525.jpgIMG_20201111_173532.jpgAnd obviously outside on low then high with the new LED's! IMG_20201111_174010.jpgIMG_20201111_174017.jpgI wish I had taken some before and afters outside too The difference is huge! Tidy work, my issue was the left hand side light was a different bulb to the right. Seem good bulbs tho and hopefully they are fine for an MOT Yours may well have been H7's on the left! usually a single filament bulb Quote Link to comment Share on other sites More sharing options...
Dean01982 Posted November 13, 2020 Author Share Posted November 13, 2020 Stu, do you know if a fazer 1999 left side bulb is h1 or h7? I I keep getting 2 different results when searching Quote Link to comment Share on other sites More sharing options...
Stu Posted November 13, 2020 Share Posted November 13, 2020 Stu, do you know if a fazer 1999 left side bulb is h1 or h7? I I keep getting 2 different results when searching This is what I have found For whatever reason the offside light on the Fazer only comes on when it’s on main beam (although it has a H4 dual filament bulb fitted).This leaves only the nearside (single filament H1 bulb) for dipped beam Which if only one comes on at high beam then that will be the H1 and H4 on the opposite side It should tell you what they are on your old bulbs Quote Link to comment Share on other sites More sharing options...
Dean01982 Posted November 13, 2020 Author Share Posted November 13, 2020 Nothing on it at all unfortunately, this is the bulb tho Quote Link to comment Share on other sites More sharing options...
Stu Posted November 13, 2020 Share Posted November 13, 2020 Nothing on it at all unfortunately, this is the bulb tho Does that bulb pull out the holder? Looks like a H1 Quote Link to comment Share on other sites More sharing options...
Dean01982 Posted November 13, 2020 Author Share Posted November 13, 2020 No its well and truly attached to the holder, it certainly looks like a H1 tho. Cheers for your help. Quote Link to comment Share on other sites More sharing options...
Stu Posted November 13, 2020 Share Posted November 13, 2020 No its well and truly attached to the holder, it certainly looks like a H1 tho. Cheers for your help. Maybe just convert it to have twin lights Quote Link to comment Share on other sites More sharing options...
onesea Posted November 13, 2020 Share Posted November 13, 2020 No its well and truly attached to the holder, it certainly looks like a H1 tho. Cheers for your help.If it's an old lamp, is amazing how well they can attach themselves to the holder..WD40 and large flat screwdriver... Quote Link to comment Share on other sites More sharing options...
