jedibiker Posted November 11, 2020 Posted November 11, 2020 Hey all.I recently stripped my grab rail back to Ali as it was shitty paint and metal looks good. (im sure you suggested it)But its shiny til touched, then grubby. So, do i need to clear coat it or use a different product. Will clear stick to bare metal. cheers Quote
jedibiker Posted November 11, 2020 Author Posted November 11, 2020 its what us yorkshire folk call Aluminium but you knew what i meant Quote
husoi Posted November 11, 2020 Posted November 11, 2020 Well. Al is the element symbol Ali could also mean Aliexpress or 1000 other names Hopefully you didn't remove the anodisation coating that prevents aluminium from corroding.Clear coat will adhere to bare metal but you should give it a pass of 400 grit (or lower) sandpaper to help with adherence because there is no chemical bonding between metal and varnish (clear). Quote
jedibiker Posted November 11, 2020 Author Posted November 11, 2020 Well. Al is the element symbol Ali could also mean Aliexpress or 1000 other names Hopefully you didn't remove the anodisation coating that prevents aluminium from corroding.Clear coat will adhere to bare metal but you should give it a pass of 400 grit (or lower) sandpaper to help with adherence because there is no chemical bonding between metal and varnish (clear). But grabrails are only made of steel or Aluminium? or so i thought.The metal was wire wooled, sanded, polished so no doubt ive stripped it right down.. lol Quote
husoi Posted November 11, 2020 Posted November 11, 2020 If Steel then you really want to have proper rust protection. clear coat is a thin layer that will only look shiny and will do buggerall to prevent rust.Al on the other hand still does corrode by reaction to acid and alkaline solutions (the white powder we see on Al mostly near the sea) so it will also need some protection before the clear coating Quote
Six30 Posted November 11, 2020 Posted November 11, 2020 lacquer it with aerosol , light coats , let each coat dry first Quote
raesewell Posted November 11, 2020 Posted November 11, 2020 400 grit is way to coarse 800 as a minimum. Quote
