Foz Posted May 3, 2008 Share Posted May 3, 2008 afternoon all!the courtesy hona cg125 ive got is starting to make weird noises its approaching 900 miles without anyhting done to it, i think it might be the oil but being courtesy bike i didnt get the manual so i dont know what the dipstick is indicating!!the noises are a kinda of quite rattly or gindy noise but i cant tell where it eminates from Quote Link to comment Share on other sites More sharing options...
yorbandit Posted May 3, 2008 Share Posted May 3, 2008 Ya not got a small round window on the side of the motor with levels on it ?? Quote Link to comment Share on other sites More sharing options...
Foz Posted May 3, 2008 Author Share Posted May 3, 2008 no its got a plastic thing you unscrew, kinda like a dipstick in a car but i cant tell whethers its high or low cos ive got no manual Quote Link to comment Share on other sites More sharing options...
Stu Posted May 3, 2008 Share Posted May 3, 2008 if its a courtesy bike surely the company who provided it should be doing things like that Quote Link to comment Share on other sites More sharing options...
Foz Posted May 3, 2008 Author Share Posted May 3, 2008 well you owuld have thought that but ive had to get the chain tightened and had the indicator bulb replaced so far Quote Link to comment Share on other sites More sharing options...
Stu Posted May 3, 2008 Share Posted May 3, 2008 hmmmm i would be having my doubts if your having to do the work Quote Link to comment Share on other sites More sharing options...
Foz Posted May 4, 2008 Author Share Posted May 4, 2008 lol oh well, been out on ti again today and it seems better i still have no explanation Quote Link to comment Share on other sites More sharing options...
Philk Posted May 4, 2008 Share Posted May 4, 2008 no its got a plastic thing you unscrew, kinda like a dipstick in a car but i cant tell whethers its high or low cos ive got no manual The dipstick must have marks on it to show high and low. Put the bike in an upright position, remove the dipstick and wipe it, put it back and screw it in, with the engine cold remove it again and see where the oil is on the stick. If you can't see ANY oil then its deffo too low. Quote Link to comment Share on other sites More sharing options...
TC Posted May 4, 2008 Share Posted May 4, 2008 hmmmm i would be having my doubts if your having to do the work I'm with Stu on this one. I wouldn't touch a thing on it because if it all goes wrong they could blame you, and then charge you to put it right.Check the paper work and terms of the loan, Insurance and any other charges you my incur Quote Link to comment Share on other sites More sharing options...
Guest Posted May 4, 2008 Share Posted May 4, 2008 no its got a plastic thing you unscrew, kinda like a dipstick in a car but i cant tell whethers its high or low cos ive got no manual The dipstick must have marks on it to show high and low. Put the bike in an upright position, remove the dipstick and wipe it, put it back and screw it in, with the engine cold remove it again and see where the oil is on the stick. If you can't see ANY oil then its deffo too low. wow, its not april the 1st is it?... ...if it has a dipstick then it will be marked with 2 levels, top 1 will say MAX and bottom 1 will say MIN...other than that, follow the advice above this.... Quote Link to comment Share on other sites More sharing options...
Philk Posted May 4, 2008 Share Posted May 4, 2008 no its got a plastic thing you unscrew, kinda like a dipstick in a car but i cant tell whethers its high or low cos ive got no manual The dipstick must have marks on it to show high and low. Put the bike in an upright position, remove the dipstick and wipe it, put it back and screw it in, with the engine cold remove it again and see where the oil is on the stick. If you can't see ANY oil then its deffo too low. wow, its not april the 1st is it?... ...if it has a dipstick then it will be marked with 2 levels, top 1 will say MAX and bottom 1 will say MIN...other than that, follow the advice above this.... Thats what I meant, still half asleep from the early start to watch the GP. Good job your here.Its NOT April the first is it Quote Link to comment Share on other sites More sharing options...
Foz Posted May 4, 2008 Author Share Posted May 4, 2008 nah oil is fine, no worries about that now and the noise have died down Quote Link to comment Share on other sites More sharing options...
