Stu Posted March 15, 2021 Posted March 15, 2021 There is a bit of an issue if you quote someone then change your mind in that you can't delete the quote as @fastbob has highlighted in another thread. The solution to this is to delete your browser cache and cookies for the forum but just remember that you will get logged out so make sure you know your password This will resolve the issue 1 Quote
onesea Posted March 15, 2021 Posted March 15, 2021 17 minutes ago, Stu said: There is a bit of an issue if you quote someone then change your mind in that you can't delete the quote as @fastbob has highlighted in another thread. The solution to this is to delete your browser cache and cookies for the forum but just remember that you will get logged out so make sure you know your password This will resolve the issue Or log on on a computer and delete it... seems to work better on a computer... 1 Quote
Stu Posted March 16, 2021 Author Posted March 16, 2021 @fastbob have you tried this? and can you confirm whether its worked or not please Quote
