Greytop Posted May 19, 2021 Posted May 19, 2021 So I decide to resurrect my venerable old RF900 which has ben sat a while. The fuel went manky so I've had to clean out the tank and strip / clean the carbs. Service gasket kit arrives so I clean the bench and start on the first carb removing & cleaning the jets then carry on to the diaphragm slider & needle. I'm cleaning the needle when I see something out of the corner of my eye and hear that slight "tink" of something heading South. So now, I have one slider/needle assembly missing its top plastic bush which is actually the seat for the long spring Can I find it on the garage floor or under the workbench? No of course. So to my question.... I can't find a replacement on eBay, at least searching for RF900. Does anyone know if other bikes share the same Mikuni carbs? Or are there any other breakers/dealers other than eBay who might be able to help? Quote
iangaryprice Posted May 19, 2021 Posted May 19, 2021 Can you post a photo of the part? If you are lucky carbs off something more comon like GSX might have th esame part. Quote
Greytop Posted May 19, 2021 Author Posted May 19, 2021 Here's a pic (not mine, from a YT video), it's the brown "flying saucer" bush at the top. I do know the RF900 engine is a cut down version of the GSX1100 but there's a main needle for sale on eBay and the picture looks different from mine (2nd pic) Quote
Stu Posted May 19, 2021 Posted May 19, 2021 item 21 on here? https://www.fowlersparts.co.uk/parts/5290842/rf900r-r-w-94-98/carburetor-model-rs check the year though Quote
Stu Posted May 19, 2021 Posted May 19, 2021 And searching for the part number brings up this https://www.ebay.co.uk/p/654434941 Quote
Greytop Posted May 20, 2021 Author Posted May 20, 2021 12 hours ago, Stu said: item 21 on here? https://www.fowlersparts.co.uk/parts/5290842/rf900r-r-w-94-98/carburetor-model-rs check the year though Brilliant thanks! Site bookmarked. Yep mine's a '96 RF900R. That's one friggin expensive plastic washer - although the alternative is a 3-cylinder RF750 I guess.. Cheers, Quote
Yorky Posted May 20, 2021 Posted May 20, 2021 (edited) 1 hour ago, Greytop said: although the alternative is a 3-cylinder RF750 I guess.. Or spend a bit more time searching for the one that you lost, it's got to be there somewhere Edited May 20, 2021 by Yorky Quote
Mr Fro Posted May 20, 2021 Posted May 20, 2021 1 hour ago, Yorky said: Or spend a bit more time searching for the one that you lost, it's got to be there somewhere Stuff like that goes down a black hole, only to turn up on the other side of the garage years later. Just think of it as having a spare... somewhere. Quote
Greytop Posted May 20, 2021 Author Posted May 20, 2021 Yeah, being an electronics engineer by trade I'm more than familiar with mm-sized parts leaving the face of the Earth for a couple of years... Actually I've just found it!! My workbench has a bottom shelf then gap of about 2" underneath with about 30 years worth of detritus including 100s of dead woodlice and spider nests, swarf spirals, cobwebs, wood shavings that sort of thing. After a few hours painstakingly sorting through the crap with a pair of tweezers the thing just shot out when scraping underneath for a bit more. So all good now 1 1 Quote
Stu Posted May 20, 2021 Posted May 20, 2021 7 hours ago, Greytop said: Brilliant thanks! Site bookmarked. Yep mine's a '96 RF900R. That's one friggin expensive plastic washer - although the alternative is a 3-cylinder RF750 I guess.. Cheers, Also try robinsons foundry for suzuki parts Quote
iangaryprice Posted May 20, 2021 Posted May 20, 2021 5 hours ago, Mr Fro said: Stuff like that goes down a black hole, only to turn up on the other side of the garage years later. Just think of it as having a spare... somewhere. It willl turn up 10mins after the replacement arrivesin the post!!!! Quote
